K3 video formats and DVD
Posted 01/02/2014 - 16:06
I can certainly verify that the K3 (and K5 / K7) do produce a video output which is 'high definition' - this is based on the pixel resolution (eg K7 is 1536x1024 at 24 rames per sec) - bit rates run around about 43,000 mbps) - on K7 / K5 .avi format this produces large file sizes, but the compression is less so editing is less demanding for computers.
K3 has moved now to the AVC format as you said - this involves higher compression, but the MPEG4 can retain higher quality at these higher compressions, giving smaller files, but its going be harder work for your computer to process them - you need a modern processor and plenty of RAM, or you may need to render (output) your projects in sections to reduce the demands on the system.
The second part of your post is not really correct - DVD does not support high definition video. The most you can get on DVD is standard PAL 720x576, and there's not much point in running bit rates beyond about 9,000mbps.
However, editors that support BlueRay disc creation will be able to output a suitable format for High Definition disc playback, and a few editors will be able to burn this to a DVD - but the DVD will only play on a BlueRay player....you'll get about 20 mins of HD video then on a single layer DVD.
The best HD format for disc play is the MainConcept .AVC at either 1440x1080 or 1920x1080 (check your K3 files properties to find the closest match to their resolution) at about 25mbps.
The best standard definition format for DVD disc playback is MainConcept MPEG-2 .mpg at 720x576.
So, the .MOV files from the K3 are definitely suitable for HD disc creation - but you need to edit and process them into the format as above and match the output format to the intended disc and playback device. Good luck with your video projects from the K3 - I'm sure the quality will be very high!
My personal recomendation for the best software for offering all the options is Sony Movie Studio Platinum
Posted 01/02/2014 - 20:14
Sure? See http://tv.adobe.com/watch/learn-premiere-elements-10/get-hd-quality-on-standard-...
Posted 01/02/2014 - 20:42
The standard for DVD players is 576i, so a normal DVD player/DVD disk you get from the local video shop etc will only ever be in Standard Definition.
However, a blank DVD is just a storage medium, that can take around 4.7GB from memory. There's nothing stopping you from burning an HD movie file onto it, just like you would copy this file onto a USB thumb drive etc. This file will play back on a computer, but most normal DVD drives will not be able to play it.
There is a bit of confusion around a DVD as an international movie format standard, and a DVD as a blank storage medium. You could copy a word document, some photos and some songs and a few HD movies onto a blank DVD disk, but a standard DVD player would not no what to do with most of it.
Posted 01/02/2014 - 21:35
JAK wrote:
John, I went on to say that a DVD disc would allow about 20mins of HD video, and that this would play on a BluRay machine. I can't see the adobe video due to low bandwidth here, but I know this applies to Sony Vegas output and disc creation - as its a format / media issue I'd imagine its the same for Premier Elements? Of course, if that programme can produce HD video that plays on a DVD machine thats great!McGregNi wrote:
Sure? See http://tv.adobe.com/watch/learn-premiere-elements-10/get-hd-quality-on-standard-...The second part of your post is not really correct - DVD does not support high definition video. The most you can get on DVD is standard PAL 720x576, and there's not much point in running bit rates beyond about 9,000mbps.
I am assuming the OP is talking about HD video that can be played via a DVD / BlyRay player, not an HD video file stored on a DVD (that could only be played on a computer media player). This is what our Kiwi member above was referring to also.
Posted 02/02/2014 - 11:50
Agreed that you cannot play HD video on a DVD player, the format is not supported. But if A DVD (or CD even) is created with the Blue-Ray directory structure the disc should play OK on a Blue-Ray player. You'd loose capacity but the 20 minutes or so is equivalent to an old cine two-reeler (about 20 minutes) so would be fine for many short productions where the capacity of a Blue-Ray disc would be wasted.
Posted 02/02/2014 - 12:42
Many thanks everyone for the very useful information you have supplied. You have confirmed what I thought. 1) That the K3 video is capable of creating HD movies and
2) the HD movie if created in AVCHD format could be burned to DVD and played on a |Blu Ray player.
Posted 02/02/2014 - 14:00
Yes, some players may be Able to play it unmodified, like some DVD players can play avi files.
This may help: http://www.avchduser.com/articles/avchd_to_bluray.jsp
Posted 02/02/2014 - 14:29
The Free Imgburn in that article is an excellent burner and it will often help you along with tips.Yes, some players may be Able to play it unmodified, like some DVD players can play avi files.
Hemel Hempstead
