K3 battery grip
Posted 15/01/2015 - 16:27
Soran wrote:
Having played with my 3rd party K-3 grip for a couple of days now, I can confirm that in the menu you can select which battery to use first(Auto,body,grip) and it will switch when one is depleted. You might only fit one battery in the grip, but there is a holder at the end of the battery tray to keep a spare SD card Cannot tell if mine has gaskets around the buttons, but it does not have any in the battery tray. I would be very surprised if my Kingma branded one is any different from the DSTE one, as they both appeared for sale within days of each other.
More than likely the same grip, there is never much in the way of seals on the battery door of the grip, it should fit snug enough so that it would have to be a downpour of biblical proportions to get any water in, it's the buttons and dials that need the gasketry, unless you are prone to dropping the lot in the drink but then it does not really matter anyway...
Cheers Jules...
Posted 16/01/2015 - 08:02
The genuine grip does have thin rubber seals around where the battery trays close against the grip itself.
Posted 16/01/2015 - 08:47
Yip thats it...
Cheers Jules...
Posted 18/01/2015 - 19:20
do you have any pics of the grip attached?
how do the buttons and controls wheel compare to the k3's?
Posted 18/01/2015 - 21:26
Replied here for you:do you have any pics of the grip attached?
link
Pentax K-3, Pentax K-5.
Sigma 8-16mm f/4.5-5.6, Sigma 17-50mm f/2.8, Tamron 70-200mm f/2.8
Pentax DA 18-55mm f/3.5-5.6 WR, Pentax DA 55-300mm f/4.0-5.8
Pentax-A 50mm f/1.7, Pentax DA 50mm f/1.8, Pentax D-FA 100MM f/2.8 Macro WR, Pentax DA*300mm f/4.0
Posted 21/01/2015 - 17:51
gtis wrote:
I see what you mean I have asked the owners to clarify it
Hiilovesaabs wrote:
Details a bit unclear. - title says 2 batteries, photo shows 2 batteries, product description makes no mention of batteries...
HiDetails a bit unclear. - title says 2 batteries, photo shows 2 batteries, product description makes no mention of batteries...
Had a reply for the owners and it comes with two batteries
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 11/02/2015 - 12:44
Hi guys, I'm just wondering what's the difference between these two grips:
http://www.dx.com/p/kingma-d-bg5-aa-lithium-battery-grip-for-pentax-k-3-black-36...#.VNtLIi4rhqF
http://www.dx.com/p/dste-k3-vertical-battery-handle-grip-for-pentax-k3-slr-digit...#.VNtLIy4rhqF
I'll go definitely to one of these, but I'm not sure which one...
Do you know the DSTE grip?
Posted 11/02/2015 - 17:07
Got the DSTE, and like it, the wheels are plastic and a little more recessed than the Pentax one there are no seals on the battery compartment but to be honest that part fits into the body of the grip better than the pentax one, it's supposedly sealed for dust and moisture (Whatever that means?). The on off switch on mine does not quite line up with the marks and is a little notchy but works fine, the grip is very robust in feel and the rubber is one of the better matches I've seen. All in all worth the money in the same way that the Pentax one isn't...
I contacted DSTE about the on off switch and they told me that it will likely loosen up with use but if I was not happy they would replace it as long as I hadn't abused it, it has not had much use yet but I can't really see there being any problems in the long run...
The Kingma I've heard of but never seen, quite likely the very same thing, you know what the chinese are like...
Cheers Jules...
Dorset
