K20D and bounce flash
pentaxian450
Posted 01/08/2008 - 00:22 Link
So far, every time I tried bounce flash with my Sigma EF500DG Super and the K20D, I get serious under exposure and flash compensation or exposure compensation don't do anything to cure the problem. Some people I know having K200D and AF540FGZ have the same problem. Some body can give me a solution or a work around? Any help or suggestion will be highly appreciated. Thanks.
Posted 01/08/2008 - 06:48 Link
Normally, when you have serious underexposure with bounce, but not with direct flash, then the bounce distance is too far.
The flash-to-subject distance is not the camera-to-subject distance, but the route from flash-to-ceiling-to-subject.
Check the flash confirmation light in the viewfinder as a start...
(Or you can roughly guess if the flash is fully discharging with a "pop" and takes a full recycle time for the ready light)
Unlocker
Posted 01/08/2008 - 13:16 Link
And if the distance is too far, time to bump up the ISO!
pentaxian450
Posted 01/08/2008 - 17:12 Link
Would 2 meters with a 2 1/2 meter high (white) ceiling be too far? No matter what I try, bounce flash ALWAYS underexpose.
Posted 01/08/2008 - 17:33 Link
It depends...
That's a total distance of about 5.4 meters.
But, it depends on (a) your ISO, (b) your f-stop, (c) the ambient light, as to how much light is actually needed.
Additionally, the Pentax metering tends to expose to maintain the highlights. This is generally a good thing - except where there are highly reflective surfaces. On the K10D at least, the "TAv" mode tends to expose the flash for a general exposure, rather than maintaining the highlights.
Personally, I find the better indoor approach is as follows:
* Use "M" on the camera
* With the flash off, press the Green button to get an exposure
* Adjust the ISO, shutter speed, and aperture so you are around 1-stop to 2-stops underexposed on the meter graph. Obviously, you're aiming for a sensible shutter speed primarily
* Now turn on the flash with TTL and shoot.
You should get perfect shots, with some of the ambient light shining through (rather than overly harsh flash). This method works a treat when using a large bounce card on the flash, with the flash pointing straight up. (See abetterbouncecard.com and make your own!)
Edited by MattMatic: 01/08/2008 - 17:33
