K20D acting very strangely
Posted 30/04/2009 - 13:27
Hi Bob, is not something to show underexposed/overexposed areas?
There's something similar on the K10D.
shim
shim
Posted 30/04/2009 - 13:28
I've scrolled through the different preview modes by pressing INFO and it has'nt changed anything - how do you activate that feature on the K10D?
Posted 30/04/2009 - 13:36
I've reset the custom menu area to default, and this has'nt changed anything - but I'm encouraged with what you've said Shim - the underexposed areas of my shots flash yellow whereas the overexposed areas flash red.
Does this sound familiar to anyone?
Posted 30/04/2009 - 13:39
Figured it out!!!!!
Go to menu; Playback display and there is an option for Bright/Dark area.
I have no idea whatsoever how this got activated...but hey - I've learnt something new.
Thanks for putting me on the right path Shim!!!
Posted 30/04/2009 - 13:40
In the playback menu under Instant review tick/untick Bright/Dark area.
Glyn
Glyn
Posted 30/04/2009 - 13:41
Yes when you look at a file that has flashing yellow & red Press the info button to stop it.
Or as Glyn has put above.
Tel,
Posted 30/04/2009 - 13:48
Cheers Guys...I was starting to panick and think about warranties and such like..phew.
Posted 30/04/2009 - 13:52
That was what's known as a quick fix Cheers Guys...I was starting to panick and think about warranties and such like..phew.
It's all about knowing where to tap with
the hammer
shim
Chester
I was processing a RAW image in-camera; then once it had saved the new jpeg to the memory card, I was browsing through other RAW files on the memory card, when I noticed pixels started flashing on and off.
For example, when previewing an image in the usual way, a dark area will be flashing on and off with a speckled yellow colour. White areas will flash on and off a uniform bright red.
I've used different memory cards and the same thing happens. This does'nt affect the actual images themselves - indeed when I go into the slideshow function they are all displayed perfectly without the annoying flashing.
Have I simply activated a feature I did'nt know about? This was'nt happening before I processed that RAW image - but the moment after it had been done, this began.
Any advice guys?
My website (Hadfield Photography)
Pentax Gallery Artist page:link
Flickr Photostream: link
