K20D
Posted 07/04/2010 - 20:36
You had the GX10 before this and they are pretty the same I believe in terms of setting, you will probably be very fastly used to your camera.
As for the settings I believe everyone has there settings of the camera differently so no use asking that
Just shoot away or get the manual and go trough all the menu options.
Posted 07/04/2010 - 20:41
OK thanks Stefan
Emma
"Photography is a way of feeling, of touching, of loving. What you have caught on film is captured forever... it remembers little things, long after you have forgotten everything." Aaron Siskind
Bodies K20D, LTL 3, K1000d
Lenses Pentax 50mm, Pentax 135mm, Tamron 70-300 macro
Posted 07/04/2010 - 20:43
Read the manual while the battery is charging and you will be fine. Have fun!
Posted 08/04/2010 - 13:25
charge battery while reading the manual
if second hand reset menus to factory default
ensure firmware is up to date
work through every menu setting to set them as you wish - pretty much your K20D will handle the same as GX10 so you can have buttons and wheels set to how they were before.
Good luck
Bob
Bob
Posted 08/04/2010 - 13:49
How will I find out what firmware it has? Still waiting just recieved email will be here between 5 and 6.
Emma
Posted 08/04/2010 - 14:04
Emma,
Turn the camera on while holding down the MENU button - it will give you a version number.
Posted 08/04/2010 - 14:05
Thanks i-berg what should it be?
Emma
Posted 08/04/2010 - 14:09
OK Thankyou
Emma
Posted 08/04/2010 - 14:56
Here this the guide from Samsung how to upgrade (Pentax works the same), simply follow the pcitures and you can't go wrong.
http://downloadcenter.samsung.com/content/FM/200908/20090813083032093/GX20_firmw...
Posted 08/04/2010 - 18:00
Well my K20D has just arrived but no grip and was supposed to be with grip
Emma
Posted 08/04/2010 - 18:06
And now they shut. Great
Emma
Posted 08/04/2010 - 18:15
That'll be a gripe then.
Posted 08/04/2010 - 18:35
They deliver a K20D, it would be much harsher if they just deliver the grip, at least you can shoot now.
Barking,
Essex
