K200D Problem
Posted 10/11/2009 - 16:05
Might be worth giving both the contacts on the lens and on the body a rub with a lint free cloth.
In Auto Pict the flash will pop up and discharge unless it has been disabled via the Fn menu.
What lens are you using?
Posted 10/11/2009 - 16:23
Hi
had the standard lens on, Pentax DA 18-55 F3.5-5.6 AL II. Have tried what you said (checked contacts) but no difference. If I go into Fn and put the flash in wireless mode (off)and then take a shot in daylight in Auto pict, I get a screen full of white, absolutely no definition whatsoever. Weird............. If I put it in Auto flash or "on" I can take a shot but obviously if there is plenty of natural light I am getting over exposed.
K200D.
Pentax 18-55mm II f/3.5-5.6 ED AL, Tamron AF 70-300mm F4-5.6 Di LD Macro 1:2, Pentax D-FA 100mm f/2.8 Macro WR
Posted 10/11/2009 - 16:48
Is your EV balance set to zero?
it's the bar you see in the right bottom of the viewfinder.
Posted 10/11/2009 - 17:22
Stefan, I think you have it! In my ignorance I thought that Auto Pict meant everything was set to a default setting and all I had to do was release the shutter. I have tried it indoors just now with adjusting the EV and it seems fine. I imagine it will be fine in the daylight tomorrow.
Thanks very much
I have checked the shots I took earlier and the Exposure Compensation on the whiteouts was 8.............
Thanks very much
K200D.
Posted 10/11/2009 - 18:13
I'm glad you've got it sorted, not half as glad as you are I bet! I hope we'll see you again.
Northern Ireland
I bought a K200D last December whilst abroad and I have used it very little. I noticed after taking some shots (on Auto Pict) in September that they were way over exposed. Not really knowing much about photography, I thought maybe I had altered a setting without realising. However I have just been out experimenting with it and the same thing is happening. Even in bright conditions the flash is popping up and going off. This of course gives me a horrible picture! Then I turned the flash off and all I got was a whiteout. The only way I can get the camera to take a normal picture is on the "M" setting on the dial. Can anyone help?
PS-It also eats batteries and hates even top grade/output rechargeables.
