k200d battery recomandations
Posted 25/01/2009 - 16:43
Just ordered these, Energizer Ultra Compact Battery Charger + 4x AA 2500mAh and 2x AAA 850mAh Rechargeable Batteries £11.95.
You can get them here:- http://www.memorybits.co.uk/shop/rechargable-batteries/energizer-ultra-compact-b...
Forgot to add they send to Spain, should have tomorrow.
Posted 26/01/2009 - 09:54
Been using eneloop with ist DL and K200D with no problems. Best thing that happened to recheargeables which is why Sony is trying to copy the product.
Cheers Pierre
Cheers Pierre
Posted 26/01/2009 - 14:03
Cheers Pierre
Sanyo actually make the Sony batteries. Sanyo Cadnicas used to be the best Ni-Cads, their first NiMh 2100 didn't seem very good and they came with a very poor charger. I've always found the older Japanese made Panasonic batteries to be about the best, but they now make them in China and make some that are like the Eneloops (i.e. keep their charge) these don't seem any different in actual use, but I suppose that if you have something like old HP Pocket PC's like I do they wouldn't run down as quick when not in use. Panasonic now own Sanyo so basically all these three makes will probably come from the same factory in future.Been using eneloop with ist DL and K200D with no problems. Best thing that happened to recheargeables which is why Sony is trying to copy the product.
Cheers Pierre
jackitec, I hope for your sake that Energizer have improved from what they were about 10 years ago. I used to only get about 4 shots from a set
shim
