K10D Remote control
Posted 04/11/2007 - 01:35
I bought a non-branded (cable) remote from eBay for about £5 ($10) and it works just fine. I'm sure the Pentax ones also work just fine but they seemed a little expensive to me for what they were.
As you've probably realised, the K10D can use two types of remotes. The cabled one plugs into the side of the camera and can be locked for long exposures - handy if you're taking photos in the dark. The wireless one can trigger the camera from the front or the rear but cannot be used to hold the shutter open in the same way the cabled one does, so it loses a little in the features stakes but makes up for it in convenience.
Which one you buy depends on what you want it for. If you do a search you'll find that several people on this forum have discovered they can trigger the K10D using remotes they already have in the house (TV, video, etc) so try all your existing buttons to see if one's on the right wavelength before splashing out on one of the wireless ones - you might very well have something suitable already under your nose!
Joining the Q
Posted 04/11/2007 - 02:06
Bill, first at all, welcome to the forum.
The remote control works perfectly as all Pentax devices, and you will find that it is a very necessary element.
Buy it with closed eyes, it worth any buck you pay for. And the only recommendation: be careful, don’t lose it (size!).
Best regards.
________________
Dirk TROTTEYN.
Best regards.
________________
Dirk TROTTEYN.
Posted 04/11/2007 - 06:45
Hi Bill
The following links might be of interest ?
http://www.pentaxforums.com/forums/85893-post3.html
http://www.pentaxforums.com/forums/84720-post29.html
http://www.pentaxforums.com/forums/84728-post30.html
I ordered this one off E-bay and IMHO it's brilliant !
Richard
Richard
Posted 04/11/2007 - 09:14
Bill welcome to the forum.
I have a generic cable release, and a Pentax IR remote.
Why?
Price on the first and size on the second. The Pentax cable release is expensive for what it is, and at least in Holland, is hard to find. The Pentax IR remote is just the smallest neatest device available and works really well. But as Dirk says becareful you don't lose it! I use an old Pentax strap with two little pockets in it - one for the remote one for the eyepiece cover. Very handy.
Why?
Posted 04/11/2007 - 12:03
And, incidentally, don't pay any attention to the Pentax claim that the battery in the Remote Control F is not replaceable. Undo the tiny screws, take it apart carefully, and you'll find a standard size watch-type battery that can be replaced easily.The Pentax IR remote is just the smallest neatest device available and works really well.
If you do find a cheaper generic one, ensure that it'll allow you to do Bulb exposures by holding the button down. The Pentax one does.
Posted 04/11/2007 - 13:55
I chose the remote release over cable, It doesn't work with the "b" setting but does have one distinct advantage, it offers mirror lock up when used on 3sec. delay. Not sure if the unbranded remotes offer this or not.
Posted 04/11/2007 - 14:01
The Pentax Remote Control F?It doesn't work with the "b" setting
It does work with B exposures (on the K10D at least). You just hold the button down for as long as you want the shutter open.
Posted 04/11/2007 - 19:28
Well you learn something everyday, your absolutely right Chris..... Also tried this with the istD and it works fine with that too, cant try the MZ7 cos' its got a film in it and I'm too tight to waste a frame
Posted 05/11/2007 - 01:25
I think I'm going to enjoy contributing to your UK forum. Excellent information posted and very friendly group of chaps. Your new friend from Boston, Massachusettts.
Attached is a link to harbor on Cape Cod, Mass. I took in Raw and played around with Pentax included S/W. Cheers!
http://picasaweb.google.com/billjaywarren/Desktop/photo#5122776757892839346
Posted 10/11/2007 - 18:23
Well you learn something everyday, your absolutely right Chris..... Also tried this with the istD and it works fine with that too, cant try the MZ7 cos' its got a film in it and I'm too tight to waste a frame Quote:
I usually use it for exposures over 30sec ...
Julien
_________________
Take a look at my photo blog.
Posted 10/11/2007 - 20:38
Julien
I used it for my fireworks shots Works perfectly Got mine 'second hand' unused for £9!
I confirm the remote control F will work in B mode.Quote:
Well you learn something everyday, your absolutely right Chris..... Also tried this with the istD and it works fine with that too, cant try the MZ7 cos' its got a film in it and I'm too tight to waste a frame impotentspider wrote:
Julien
