K10D Flash Modes
Posted 19/10/2006 - 13:18
These are all modes for the popup flash.
* Leading curtain (the default): Shutter opens, flash fires, shutter waits, shutter closes.
* Trailing curtain: Shutter opens, shutter waits, flash fires, shutter closes.
Doesn't sound like a lot of difference, but the net result is that when using trailing curtain with a slow shutter speed and a moving object it looks far more natural - the "trail" is effectively back in time.
HTH!
HTH!
Posted 19/10/2006 - 15:43
Thanks Matt
Would I be right, therefore, in saying that leading curtain, at a slow shutter speed, will leave a trail going "into the future"?
Would I also be right in saying that if the shutter speed is set at flash sync speed, whatever that may be for a particular camera, there will be no trail either forward or backward?
Graham
Graham
Keep up the good work
Graham
I'll think of something someday.
Graham
Posted 19/10/2006 - 15:48
Graham,
Yes, you're right - leading flash will give a "future" trail. That's why it looks so "wrong" in moving subjects.
You can still get blur at the flash sync speed. Don't forget the flash duration is something like 1/10000s, so it depends just how fast the subject is moving as to whether the 1/180 or 1/150 makes a blur
20 years
• Flash On
• Flash On + Red-eye reduction
• Leading curtain sync (slow)
• Leading curtain sync + Red-eye
• Trailing curtain sync (slow)
Graham
Graham
