K10D display not working
Posted 30/01/2013 - 10:51
You could try re-installing the firmware again see if that helps. Get it from HERE.
What happens when you check firmware version? Just hold down the menu button then turn it on, it SHOULD display the version number in the middle of the screen, Ver 1.30 or something should appear.
Hope this help!
Hope this help!
Posted 30/01/2013 - 11:24
I know this may be a really daft question, but were you wearing glasses at the time? I once had the same thing before realising my polarised glasses were preventing me from seeing anything on the screen, even though the camera was fine.
Posted 30/01/2013 - 15:32
I know what you mean about the polarized lenses, but I wasn't wearing them.
I tried checking the firmware, but the screen won't even show me that.
Posted 30/01/2013 - 17:40
Low battery as in this thread -
http://www.pentaxforums.com/forums/pentax-dslr-discussion/94026-k10d-back-displa...
This has references to the problem being caused by a defective memory card, or the memory card door not properly shut -
http://www.fixya.com/support/t209535-pentax_k10d_both_lcd_screens_blank
Ehow says - "lso, some people experienced their camera freezing up after a lens change or a memory-card replacement, and had to send their camera back to Pentax for repair."
Sounds like you have tried most of the above. Memory card door closed?
Good luck, hope you get it sorted.
Paul
Paul
K3ii, DA16-85, DA35mm Limited, FA77mm Limited, 55mm f1.8 K, 135mm f3.5 M, DA300, DA 1.4 HD TC,
DA16-45, Sigma 15mm f2.8. Cosina 100mm f3.5 macro
13 years
