K10D Deserves better lenses.
Posted 04/06/2007 - 21:29
hi
why not focus only about the good old pentax smc(200mf2.8,28mm3.5,100mm2.8,85mm ect ect ...)
plastic is cheap ,metal is graal [/quote]
Posted 04/06/2007 - 21:46
Because I can't get any
I found:
http://www.bdimitrov.de/kmp/lenses/zooms/long/FA70-200f4-5.6.html
relatively cheap but have not decided if it would be any good on a K10D.
I really want to have the weather sealing on my K10D functional with the DA* lenses though. Was caught out in the rain today, had to very quickly put all equipment away in my backpack.
I found:
Posted 09/06/2007 - 17:50
I'm surporised that you don't find the quality more exciting from these very competent lenses.
How are you viewing the images? Processed in Photoshop? On a monitor? As a print? How large a print?
I've seen plenty of stunning A3 prints from the lenses you list, and they stand up to any marque in competition.
Posted 09/06/2007 - 18:51
Only on screen in Lightroom, it is much better than the old FujiFilm S20Pro (especially noise wise). I just expected to be able crop images a little more, the detail when looking at the inner 2MP on screen isn't quite as good as I'd have liked.
Blending when printed is better, but when examined closely you can see that there is a little lack of detail.
As soon as I put on the old A-50 1.7 the sharpness improves significantly. Shame it is only manual focus as this can really slow things down. I use it for portrait, still life and low light shots where I have time to focus.
Posted 09/06/2007 - 20:06
I think one of the basic requirements is to sharpen, not too much but enough to crisp up the detail. When this is done results are definitely impressive.
Looking very closely at prints is something a lot of judges do, but it isn't realistic. prints have a natural viewing distance, so a 6x4 inch print is looked at pretty closely but an A3 print usually much further away.
At the correct viewing distance a print should look sharp, but viewed unnaturately closely it will lose it. This applies to silver prints as well as inkjet ones. Viewed too close, a print from an FP4 negative will not be sharp - in a different way to a digital image, but the end result is the same.
Posted 09/06/2007 - 20:11
I've been using my K10D with the FA 24-90... what a combination
My 18-55 is used on the *ist D, and the 24-70 EX Sigma gets little use...
I am also waiting for the DA* lenses
Posted 10/06/2007 - 13:45
I'm on to my second 70-210F (the first got mouldy) both bought second hand for about £40. It focuses far faster than my Sigma 70-300 on my cameras and the results are very sharp from f8 and acceptable wide open. I have found that it tends to be better both in terms of the AF and sharpness with subjects further than about 2m away but you can use the minimum focus distance if you need to. At mid range I think it is a match for any lens. I also have the 28-70 f4 which is a bit plasticky and light but again gives very sharp results. I think that one cost me £60. You could get the 35-70f which pairs up with the 70-210 and is equally well made and sharp. I think mine was £40. I have the Samsung GX10 (sorry but I didn't buy it) which came with their 18-55 lens which apparently is the same lens as the Pentax which is reasonable from f8 but I have never used the 50-200.
Carl
Carl
Used Pentax for the last 25 years. (Me Super, SFXn, Z1, MZS and istD-still got them all) and won a Samsung GX10 in a comp earlier this year
West Midlands
I'd like to be able to crop some of them as 200mm (300equivalent) isn't quite good enough to get within shooting distance for birds. Unfortunately, there seems to be a wide are and quite a lot of soft edges. I know this usually improves when printing, but not really that much when you print a large image.
I really can't wait for the DA* lenses.
I must say results are still reasonably good considering the price of the lenses.
(I always shoot RAW and work in Lightroom)
Dan
https://www.flickr.com/photos/honourabletyr/
