K10D Battery grip
Posted 23/08/2007 - 13:19
I have a battery grip for my K10D but want to know if I put my second battery in the battery grip and also have my other battery in the k10D body is this doubling the power/life etc..
What does the instruction manual say?
Posted 23/08/2007 - 13:45
Pete
To save reading the manual the answer is yes. Having batteries in both body and grip does double the battery life if both are charged. At least, that's how I understand it from just skipping through the manual - I only got my K10D on Tuesday, so I'm still learning!!!!I have a battery grip for my K10D but want to know if I put my second battery in the battery grip and also have my other battery in the k10D body is this doubling the power/life etc..
Pete
You can even choose which battery the camera takes it's power from first (automatic, body first or grip first). On automatic mode the camera drains down the battery with the lowest charge first.
Edit: A quick check of the manual confirms this. See the section "Selecting a Battery" on pages 198 and 199.
P.S. Pete, you mean you've had your K10D since January and you've not read the manual yet?
Posted 23/08/2007 - 13:55
Cheers Guys
Dont do manuals
No seriously I didnt know this info would be in the manual Yes I know should have checked first
Pete
Dont do manuals
Pete
Wedding & Portrait photographer
Only downside to the battery grip so far is it does not feel like you have as good a grip as the cameras own body grip, Its not as deep in other words.
Personally, I have to disagree. Have used the Canon 20D with grip and I dislike the feel a lot. The *ist-D and K10D have beautiful grips that are rock solid - I do a fair bit of one-handed shooting and switch between portrait and landscape by a throw-and-catch method (with the strap round the neck I hasten to add!).Only downside to the battery grip so far is it does not feel like you have as good a grip as the cameras own body grip, Its not as deep in other words.
Each to his own though
As far as battery - I generally just use the grip battery alone. A custom menu function chooses which to use first if you have both. But be aware that the camera will drain the first battery and show that you've died... then you power off and on again to continue shooting with the other battery (you wouldn't know one was dead if it just kept shooting until they were both dead).
But, as I say, I find it fast enough to change batteries to use only the grip battery.
Posted 23/08/2007 - 14:04
Dont do manuals
Of course - there's no point when you have a whole forum full of people that can look it up for you.
Dont do manuals
Posted 23/08/2007 - 14:11
Cheers Guys
Dont do manuals
Pete
I read the manual several times before I even received my camera...
Cheers Guys
Dont do manuals
Pete
Posted 23/08/2007 - 14:22
I still have the occasional poke about in there even now, 7 months down the line, and once in a while I still trip over something new. Like only yesterday I found out how to do multi-exposure..
Posted 23/08/2007 - 14:36
Multi-exposure in camera is so slow that it can be rather useless. You don't keep the 3fps shooting speed which you really need to combine a lot of sequences.
Posted 23/08/2007 - 14:51
Fair point.Multi-exposure in camera is so slow that it can be rather useless. You don't keep the 3fps shooting speed which you really need to combine a lot of sequences.
There's a fair bit of processing to do though, I guess, especially if you have auto EV on, so I suppose it's not surprising.
I can't see it as being the sort of thing I'd use often, but it's not quite so gimmicky as the slimming filter...
... which, as it happens, I did find a use for recently. Although I did it on the 'puter, not in the camera....
Posted 23/08/2007 - 15:00
I find the multiple exposure mode useful.
While scouting around for a location for a video project, (I'm doing for my kids Halloween), we did this shot. The multi exposure mode combined with a "Day for Night" shooting technique (using custom white balance, slight underexposure, contrast maxed, and colors muted set in camera, jpeg) resulted in this image...we were able to get an approximation of what we wanted our video to look like, in the feild in camera. the final image was tweeked in photoshop, only using standard darkroom type dodging and burning....the goal is to get the video done (mostly in camera) to match this look:
Posted 23/08/2007 - 16:14
Pete, one thing with the grip is that the battery usage may not be as expected or desired. I choose to expend the battery in the grip first. (as opposed to in body first, or both/simultaneous).
The issue is that when the battery in the grip dies, the camera stops working.
You have to manually power the camera off, then back on in order for the fresh in-body battery to kick in. Of course, if the power is off too long, the grip battery "self-charges" back to a point where it will be strong enough to tell the camera that it is OK to use it. So you have one or two shots, and you have to power off/on again.
Rather annoying, as I'd prefer the camera to know what to do when one battery dies without me having to power the thing off first.
And THAT is not in the manuals.
Otherwise, I would probably not use the camera as much without the grip. It is so much more comfortable to hold.
Posted 23/08/2007 - 16:15
I only just found that Pentax have a PDF of it on their website so I could have been busy reading before the camera arrived on Tuesday! I read the manual several times before I even received my camera...
Have downloaded it to my USB key so I can check it out during lunch at work without having to bring the manual in with me.
I love the end result. Very cool! I find the multiple exposure mode useful.
(Note to self. Read the manual and find the bit on multiple exposures!)
Posted 23/08/2007 - 16:23
Curious about this.Otherwise, I would probably not use the camera as much without the grip. It is so much more comfortable to hold.
I've held my brother's *istD with grip but that's a much smaller camera, so I can see why it might be better.
What makes the '10 more comfortable to hold with the grip? Is it just the height that fits the hand better or is there something more to it than that?
Posted 23/08/2007 - 16:40
_________________
Dave Appleton
shooting in the afternoon beats the heck out of stumbling around cemetaries at night.I love the end result. Very cool!
_________________
Dave Appleton
use a yellow card, or gel to set your white balance (then put the gel on your lights yo color corect anything you're lighting with them) to maintain consistancy between your video and still cameras.
West Mids UK
I know If I put just the one battery in the battery grip it works my camera fully the same as the other way round if it were in the body itself. ???
Only downside to the battery grip so far is it does not feel like you have as good a grip as the cameras own body grip, Its not as deep in other words. I have handled a few other cameras with battery grip and they seem a little better to hold. Its not important just and obsevation
Pete
