K10D+ 16-50 - underexposure with Slave Flash
Posted 06/08/2009 - 11:25
Its a Pentax!
Pentax K10D, 18-55+ Digital King 0.7x, 50mm, 16-50mm DA*
Posted 06/08/2009 - 11:40
Make AND MODEL!
Posted 06/08/2009 - 12:50
I'm sorry to say you've bought a little fill in flash that is manual and uncontrollable. All but useless in your situation, I'm afraid.
In the wedding situation it may well be that the flash hadn't fully re-charged before you took the next picture
Posted 06/08/2009 - 13:01 - Helpful Comment
If you're triggering the Xtra flash from the pop-up, it'll be the pre-flash that triggers it.
So by the time the shutter opens, the Xtra flash is all over and done with, and will contribute nothing to the exposure.
It may be even worse than this - if the camera's metering sees any of the light from the Xtra flash, it may, in addition, think the scene is brighter than it is.
Underexposure is pretty much guaranteed, without there being anything wrong with the equipment.
Posted 06/08/2009 - 13:13
Yes Ken, thanks possible that the flash hadn't re-charged fully before I took the next picture- I will check the setting where it blocks taking a picture if flash not re-charged.
About the Xtra Flash, I had read:
"With digital cameras you have to be careful that it fires at the same time as some have a preflash system that fools the slave to fire out of sync. "
Chris, could I ask if there is a way around the pre flash, or as Ken has said, the Xtra Flash will not work with the K10D?
Posted 06/08/2009 - 13:25 - Helpful Comment
There are two ways that I know of.Chris, could I ask if there is a way around the pre flash, or as Ken has said, the Xtra Flash will not work with the K10D?
One is to use a pre-A series lens, or an A-series lens (or FA series) not set to A. The pop-up then doesn't emit a pre-flash, and triggers the Xtra flash just fine.
However, you'll have to do all the exposure manually, and ensure "Use Aperture ring" is set to permitted in the Custom functions.
The other is to use an old non-PTTL flash gun in the hot shoe to do the triggering.
Edit: or a PTTL gun in A or M mode. I've just tried it with the Samsung version of the AF 540, and it works fine. Again, you'll have to get the exposure sorted out by trial and error, I expect.
Posted 06/08/2009 - 13:34
ChrisA wrote:
[quote:3496ace15f="Ravi"]The other is to use an old non-PTTL flash gun in the hot shoe to do the triggering.
which, ironically, probably cost less than the one you bought. You must be disappointed but at least it didn't cost a fortune and you might still find a use for it.
Posted 06/08/2009 - 23:39
OK! I will surely give it a try: it may be cheap, that wil make it all the more fun- if it works!
That's the fun of digital!
Thanks for your help, and comments.
Rgds
Rgds
Posted 03/09/2009 - 00:53
Hi bought one of these Xtraflash units that Ephotozine was offering on sale and it functions correctly ok,
the problem is all I get is black photos.
using pentax k 10 set to f5.6 100 iso, flash on, take photo all is ok.
as a above and as per Xtra flash instructions place xtra flash at 2 meter from the subject , take picture camera flash and xtra flash both go off and the result is a nearly black image.
I am obviously missing the point somewhere can some explain what I am doing wrong?
I have tried setting the speed to 1/125 but get the same result.
tried x [=1/180] flash setting same result
why does the image look as if it is vastly underexposed? I thought to much light will look washed out / horribly overexposed is that not correct?
I am not using red eye reduction which would cause early slave flash or in place so dark the pre-flash goes off to set auto focus. I have tried on manual focus as well, but unless the slave is a long way away , further than the supplied chart suggests then I get these very underexposed image.
Alistair
Alistair
Assorted Pentax bodies and lenses as well as Sony and Olympus kit
Posted 03/09/2009 - 05:57
If I understand you correctly and as ChrisA explained in his post, its the pre flash on the pop up flash that is triggering your Xtra flash, so The Xtra flash is not contributing to the exposure as the flash has already gone off before the picture is taken.
Get yourself a little Pentax AF 160 flash and use that as the trigger for your Xtra flash.
Camera:|K-7|
Quidditch (Worcs),
UK
I bought a slave flash, & have tried it, but it gives very underexposed results...
I have seen the video on how to use it, should be straightforward, but haven't been able to get it right
Also, at a wedding, I used the 16-50 with K10D's built in flash, & got some very underexposed results...
I emailed the results to SRS, they were helpful & have offered to look at the camera's metering, but back at home, I got no problems! Must've been the strobe lighting at the wedding that "threw" the metering
OR,
I was too quick on the button!!
Anybody with slave flash experience, please help!
Thanks a lot- Ravi.
