K10d + Metz 48 remote underexposure
Posted 13/03/2010 - 13:34
Hmmm no help yet since I don't have a metz 48 I can help you fully but first some questions.
Does the Metz flash in wireless since I can't make that out of your comment.
If not a simple things to do is set the flash on the camera and turn the flash on and set it to wireless.
Then turn the camera on and select in the Fn menu also wireless flash, in the top display you will see CH 1,2,3 0r 4 those are channels and if it's correct the flash automaticly picks that up now.
Press the shutter and remove the flash and then it should trigger the flash with the help of the build-in flash.
ps. you can set the build-in flash to control in the custom menu, then it wouldn't contribute flash to the photo.
Posted 13/03/2010 - 21:57
Stefan, thanks yes it all works as you describe it.
Gareth, some thing is not right at all,
whether it is on the camera or not the following applies.
If the camera set under 400 ISO it produces a weak flash and low range on the screen.at 400 or higher the range on the display starts to match the actual effective flash range.
the flash adjustable ev need to be + 2 to get a decent flash result at the 400 ISO or higher setting.
the displayed zoom is not correct with a 18-55-55 kit lens at 55 it says there is 85 mm lens on and so on.
I have used the reset on the flash back to factory settings but it still does the above.
Alistair
Alistair
Assorted Pentax bodies and lenses as well as Sony and Olympus kit
Posted 13/03/2010 - 22:01
Question - have you updated the Metz firmware ?
let the education continue
Posted 13/03/2010 - 22:07
no but I only bought it this week at the imaging show at the NEC should be up to date I would have thought but I can try it.
Alistair
Alistair
Posted 13/03/2010 - 22:18
Have you adjusted the flash compensation on the camera maybe?
Posted 13/03/2010 - 22:19
It's worth a shot - but Metz don't support Macs so if you are a Machead [ like me ] you will have to get someone to do it on a PC.
Posted 13/03/2010 - 23:18
Just checked on the Metz website and the version installed is the current one.
Alistair
sent this to Metz which is a bit more accurate that what I have prvously posted.
Fitted to a Pentax k10d and with the flash in P-ttl mode and the camera set to Av mode.
I find the following:-
At any shutter aperture the flash does not produce enough flash it needs +2 ev compensation to work correctly.
This applies to on or off the camera.
The zoom setting is completely wrong. If I fit a Pentax 18-55 lens and set it at 55 mm the flash says it is at 35mm. If I set it at 50 mm it says 35 and at 35 it says 24.
The displayed range on the flash is very short if the ISO is set at 100 and if used as a guide with out the +2v compensation the image is underexposed.
If the ISO is set at any speed lower than 400 ISO the range is very short and in fact at 100 iso that the displayed distance is only 5.5 metres not 35 as distances predicted on table one with the flash showing a zoom length of 50mm [bearing in mind to get that display in fact the lens is actually set on 35mm as described above. .
The resetting the auto zoom as described on page 77 does not work. You can only reset the zoom from manual by switching off the unit. The flash does not do as described if, you go past 105mm it goes to the minimum zoom setting.
Your help will be appreciated as clearly having to set the unit to +2 ev to get a decent flash and having to set the camera to over 400 iso to get range that I bought he flash for cannot be right.
Thank you
Alistair Barclay
07888131892
Metz 48 AF-1 on the box mb48 af-1p bar code 4003915048026 I don’t see a serial number
Alistair
Thank you
Alistair Barclay
07888131892
Posted 13/03/2010 - 23:34
adwb wrote:
JI find the following:-
I need +0.7 EV with my flash, P-TTL is known to underexpose to 1 stop but 2 EV is too much.JI find the following:-
Could be right, focal length is not what count but the angle, it could be he is using the right angles but is stating the focal length for 135/full frame cameras.The zoom setting is completely wrong. If I fit a Pentax 18-55 lens and set it at 55 mm the flash says it is at 35mm. If I set it at 50 mm it says 35 and at 35 it says 24.
35mm x 1.5 = 52.5mm
24mm x 1.5 = 36mm
For the rest it seems the flash isn't listening
Posted 14/03/2010 - 17:53
I found the solution in a previous post on this forum and it works perfect exposures just about every time.
Alistair
4,509 postsJoined: 02/07/2002
Link Posted 10/07/2007 - 13:25
In response to several people who have had "issues", I'm reposting this note as a sticky. The original was on this thread. Just copied out verbatim.
Hopefully, those of you who are experiencing "odd" flash issues can check out this guide to see if there's something you've missed
- For controlled situations you can use an "non intuitive" setting I have done the following in a number of situations: Turn off the flash; Set the camera to "M"; Meter the scene using spot metering to try and expose near the highlights; Ensure the shutter speed is under 1/180s; Turn on the flash in P-TTL mode; Take the shot. Every time this is a winner - the flash fills in the shadows without changing the exposure. (I have used this for taking shots in dark rooms that have light streaming in and got shots that have everything properly exposed ).
- For wireless, the "Slave 1" is the "intelligent" mode (for the *ist-D and K10D only). "Slave 2" is the "dumb" mode which will sync to all pop up cameras - however, if the camera has a preflash, make sure the flash only uses up to half power otherwise the main flash will be exhausted (and used up on the preflash). See page 49 of the AF360 manual. Custom options in the K10D and *ist-D can be set to use the pop-up as a trigger only
Alistair
Posted 17/03/2010 - 13:01
Some of the old posts are the best
Glad it helped again
BRISTOL ENGLAND
it all seems to work well but for some reason if I have the Metz off the camera the flash works but at any distance it seems to not give enough light and results in dark images which look like the result that you get if you used the built in flash to far away from the subject.
I doubt this is a known fault so I must have something set wrong, has any one a step by step set up for the k10 and the 48 if used remotely?
Alistair
