k100d memory card error
Posted 29/10/2015 - 23:35
Hi, SD cards work in SDHC readers but not the other way round. Down to the age of the camera when such cards didn't exist. Your camera card slot would also have an upper limit of 32GB I guess.
Posted 30/10/2015 - 00:34
There is a firmware update for the K100D that allows the use of different/newer model SD cards, so you will have to do this. I had to on my K100d, for this very reason. You'll obviously need a card that works with the camera to undertake the firmware upgrade procedure.
http://ricoh-imaging.ca/en/support/digital/k100d_s
It's an old camera now though and memory tech has advanced. If the firmware update doesn't help then you'll have to sauce an earlier model/lower spec card.
Posted 30/10/2015 - 07:21
I've never used such an advanced card with my K100. Try a cheap SD card, I bet it'll work fine once formatted. (You'll get some lovely shots from that old sensor.
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
Posted 30/10/2015 - 07:48
Get yourself a cheap 4GB or 8GB SDHC card, use that for the update and keep as a spare once you've got the other one working.
Chris
Posted 31/10/2015 - 14:35
nearly sure until you update the firm ware the max size card you can use in the k100d is 2gb I have a k110d and that was the case
11 years
