K10 Electronic Interfaces
Archivist
Posted 12/09/2007 - 12:29 Link
I am in the throws of deciding that a K10D is the camera for me to purchase as my "coming of age" (60) present from the wife. Having a great interest in virtually anything electronic I like to push the limits on almost everything I purchase. Consequently I wonder if anyone here as identified the various interface connections and specifications for such things as shutter release and power supply. Having shutter release connections for the CS205 Cable Switch, IR release and connection on the battery grip opens up all sorts of opportunities for visual, sound or motion triggering of the shutter although it looks as if connector sourcing might be a problem for homebrew solutions. If it hasn't already been done then I may well be the guinea pig!
(Still using my HP912 (same as Pentax EI2000) camera I think I will notice the difference!)
Posted 12/09/2007 - 12:49 Link
Mike,
I've documented the CS205 interface elsewhere on here, and also the Infra-Red trigger sequence.
I think the power supply for the K10D is special - at least the connector is - and you'd be wise to get the real thing
As far as CS205 and IR - there's absolutely no problem doing DIY
EDIT:
CS205 pin-outs:
https://www.pentaxuser.com/forum/viewtopic.php?t=266
IR:
https://www.pentaxuser.com/forum/viewtopic.php?t=378
Also, there's USB remote control of the K10D using the Pentax software
Daniel Bridge
Posted 12/09/2007 - 12:57 Link
The CS205 connection is simply a 2.5mm stereo jack plug. A closed circuit between tip and ground will fire the shutter, between ring and ground will activate the autofocus.
So any circuit which closes a contact, either electronically or physically, should be able to be used to trigger the shutter and/or activate autofocus.
Have fun and post your results!
Dan
Daniel Bridge
Posted 12/09/2007 - 12:58 Link
That's what happens when you wander off mid-post, Matt gets in there first!
With a far more comprehensive reply, I have to say.
Dan
Daniel Bridge
Posted 12/09/2007 - 13:42 Link
Oh, and in case it's of use to your DIY tinkerings Archivist, I have used approximately 80 feet of extension on the cable with no problem. Thread here...
https://www.pentaxuser.com/forum/viewtopic.php?t=2663
Dan
Posted 12/09/2007 - 13:50 Link
Dan, now you're boasting LOL!
Mac
Posted 12/09/2007 - 13:52 Link
See how the technocrats run off with the details and leave to an ol' geezer like me to notice that this is your first post?
WELCOME!
This is a wonderful forum, and we'll enjoy your visits!
Mac from Montreal
Posted 12/09/2007 - 17:54 Link
Guilty
Sorry Mike! Welcome aboard
Daniel Bridge
Posted 12/09/2007 - 18:01 Link
Guilty
I didn't even realise Mike had put his real name on there, so double apologies from me!
And a belated welcome.
Dan
Archivist
Posted 12/09/2007 - 19:53 Link
Many thanks for the warm welcome and valued information .... now to purchase a camera and be able to put to use some respectable lenses I stored away when I stopped using my P30 camera!
I shall certainly post results of any experiments I carry out.
(Archivist of Biggleswade History Society)
Posted 12/10/2007 - 10:46 Link
Before this tread disappears even further into oblivion, does anyone know what type of plug is used with the power pack socket on the Pentax AF540FGZ flash units - name, brand, or source?
If anyone has the TR Power Pack III, a couple of good images of that plug would be very helpful as well.
stewart
kiq
Posted 26/10/2008 - 09:04 Link
I think this plug is "Pentax original", so you can't find it in Radio Shack.
Does anyone know pinout of the plug, or can measure with multimeter?
