k10 d multi exposure question re ghosting images
Posted 29/08/2009 - 16:29
the principle is simple....
you are effectively taking a proper exposure and dividing it by the number of frames you intend to (think of a 'stack') take.... for example 2 frames= each exposure divided by (underexposed) half... to get two shots of a person to expose properly, you need to
a) get them to hold perfectly still for both shots (or more) which is not easy..
or
b) light them to get a proper exposure for one shot, then remove them or keep them in the dark for the other exposure...
or
Posted 29/08/2009 - 16:41
Don, thanks for the almost instant reply, I hardly had time to make a cup of coffee before my pc "pinged" to tell me a email had arrived.
So if I take the first shot with for example me ij it then the subsequent ones with out me it will not ghost? is that correct?
but then how do I get the "twin" effect that i have seen? in one image there was a boy who moved several times running which froze him in differnt position on the image but he was fully exposed and the back ground was also as well,?
Alistair
Never Play Leapfrog with a Unicorn.
Alistair
Assorted Pentax bodies and lenses as well as Sony and Olympus kit
Posted 29/08/2009 - 19:59
On a multiple exposure, each object/subject that is moved will appear translucent. The only way to do what you want is in post processing. You can do it very easily in Photoshop Elements or Paint Shop Pro using masks.
Posted 29/08/2009 - 20:33
Yves, thanks, I have come to realise that, never mind, in the course of the research into this I have found other uses for the ME feature that are not mentioned in the Pentax hand book or I gather some of the other books on the K10
Alistair
Alistair
Posted 29/08/2009 - 22:38
Alistair
can be done in camera... try covering half the frame with a black card over the lens for one PRoper exposure, then place it over the first half of the frame for the second exposure..Don, thanks for the almost instant reply, I hardly had time to make a cup of coffee before my pc "pinged" to tell me a email had arrived.
Alistair
or if your image is dark over all, place your subject on one side, and use flash to light the subject, then move the subject to another spot in the frame for the second exposure...
the trick is to use full flash exposure on your subject, and half expose the static parts that will get exposed twice...
Posted 29/08/2009 - 22:39
Alistair
Alistair
or if your image is dark over all, place your subject on side, and use flash to light the subject, then move the subject to another spot in the frame for the second exposure...
the trick is to use full flah exposure on your subject, and half expose the static parts that will get exposed twice...
Posted 29/08/2009 - 23:13
It can be done that way, but you always get some light that "leaks" into the covered part of the lens/sensor, doing some softer pictures. Easier in post. I generally try to get it right in camera, but this is one case where you want to get it right in post.
Posted 30/08/2009 - 11:42
Can you do multi exposure with the K10D?
Posted 02/09/2009 - 23:17
How? I would be interested to know. Thanks
Posted 02/09/2009 - 23:41
In the "record mode" menu, just go to "multi-exposure", and "fill the blanks". Once you know where to look, it is self explanatory. Have fun.
(I can't be more accurate, since I sold my K10D, and those info are "off the top of my brain").
Posted 03/09/2009 - 08:41
thank you
BRISTOL ENGLAND
I have read articles re water effects that I understand and using the feature to take several short exposures rather than one long one and the benefits of doing this but how to get a pair of me in a photo that is not ghostly eludes me.
Alistair
K10d and K-m and way to many lenses and gadgets.
