k1 help
Posted 10/04/2023 - 17:36
Posted 10/04/2023 - 17:49
It's stuck on m and the flash symbol on the rear screen and turning the wheel to tav or any other the m and symbol it stays the same
Posted 10/04/2023 - 22:18
If you remove the camera battery, wait a few minutes and then re-insert it might reset the camera and solve the problem. I presume you can't get the camera to actually do anything? If you can, then a factory reset and/or firmware upgrade might do the trick.
Posted 11/04/2023 - 13:00
Thanks for all the help
but was unable to fix so its gone back to ice under warranty
Posted 12/04/2023 - 16:19
My K1is exactly the same. I've just assumed that's how it was meant to be. I don't reckon this is a fault, just a "quirk" in the software, deliberate IMO.
It does make life simpler when using a flash. Connect the flash and switch the flash on if you want to take a flash shot and then switch the flash off if you don't want a flash shot. Quick and easy, saves messing about in the camera menu.
Posted 12/04/2023 - 17:18
Thanks but is your k1 stuck on m
And you can't change it on the mode dail
To tav etc
To tav etc
Posted 12/04/2023 - 18:46
No.
But just a suggestion, you haven't accidently locked the button have you. It's easily done and the first time I did I thought the button was jammed.
With regard to the flash, the flash on the K3 III is also on all the time although the symbol doesn't show
Posted 12/04/2023 - 19:02
Hopefully lce will sort it out
Thanks for your help the k1 is still new to me and a lot to learn
but a fab camera
but a fab camera
Posted 12/04/2023 - 19:36
1.Check your settings are not locked.
2. There was an issue with early K-1's where the mode dial is locked on M mode.
I suspect this is your issue. Nothing to do with flash settings.
worcestershire
help please
