K1-HDR
Posted 17/02/2019 - 20:57
Don't they control the degree of blending intensity?
Auto from memory always gave the most natural results, and things got progressively more extreme from there.
Not sure if that's different on the K-1?
Posted 18/02/2019 - 01:51
You will have to do what I will now have to do ..... play with it and see !
Posted 18/02/2019 - 04:54
Thx for the feedback. K1 Manual is useless on this. Have not found any info on this. So does the bracketing value adjust the effect even in Auto or Adv (whatever that means) mode?? Appreciate any info. Greg
Posted 18/02/2019 - 05:50
The bracket value will affect how much the dynamic range is increased by.... -3/+3 will be the most.Thx for the feedback. K1 Manual is useless on this. Have not found any info on this. So does the bracketing value adjust the effect even in Auto or Adv (whatever that means) mode?? Appreciate any info. Greg
Use auto align if you are handholding the camera.
Posted 18/02/2019 - 19:29
Glospreys wrote:
Don't understand the relationships on the K1 re. HDR (Menu or Smart Function). What effect, if any, does setting the Bracketing Value (1, 2 or 3 stops) if set HDR Capture to AUTO or Advanced? Or If set to Capture to HDR 1 does it shot 3 images with 1 EV bracket, HDR 2 to 2 EV, etc?? And what is the difference between HDR AUTO and HDR ADV?? Thank you.
Perhaps info found in the links below may be of some benefit to you.Don't understand the relationships on the K1 re. HDR (Menu or Smart Function). What effect, if any, does setting the Bracketing Value (1, 2 or 3 stops) if set HDR Capture to AUTO or Advanced? Or If set to Capture to HDR 1 does it shot 3 images with 1 EV bracket, HDR 2 to 2 EV, etc?? And what is the difference between HDR AUTO and HDR ADV?? Thank you.
https://www.pentaxforums.com/forums/190-pentax-k-1/327397-k-1-hdr-settings-quest...
https://promotesystems.zendesk.com/hc/en-us/articles/115005952088-Example-HDR-wi...
C.O.L.B.A.S victim
7 years
