K-r not working with SMC M 2.8 28mm
Posted 12/01/2011 - 00:26
Custom setting "using aperture ring" needs to be set to "permitted" after which you can use your M series lens in manual mode. You need to stop down the lens to take a meter reading and the reading may not be accurate, but you can use the lens.
To avoid any of this inconvenience, any lens that has an "A" on the aperture ring will be fully functional. This means lenses from the A series onwards.
Posted 12/01/2011 - 00:27 - Helpful Comment
Here is a link with a guide for the K-x. I'm pretty sure the K-r will be very similar. http://support.pentaximaging.com/node/1
Posted 12/01/2011 - 00:29
You need to change the apperture ring setting on the camera menu to accept manual lenses.. All will be fine and dandy then. Cant be more exact not got the manual at hand..
Stuart..
Stuart..
Posted 12/01/2011 - 00:30
Oops John beat me to it...lol
Stuart..
Stuart..
Posted 12/01/2011 - 03:06
You may also need to turn the body onto manual focusing if you are trying to take an out of focus image (or one where the the point of focus is not central).
You will not get the aperture value on the body as it has no way of knowing what it is (see John's comment about A series lenses).
I have heard that the K-5 stop-down metering with older lenses is more accurate than it was with the K10/K20. I'd be interested to know if this is the case with the K-r.
K.
K.
Posted 13/01/2011 - 17:27
i used the same link that blythman has given and it works with my k-r and a few m series lens's that i have and a couple of vivitar lens's i use and they take good images just remember to stop down the lens and meter with the green button.
geordie
geordie
Posted 15/01/2011 - 18:09
Thank you all. I have now got the camera set up and am enjoying my new lens!
I am off to Svalbard in late February so am hoping for some Northern Lights. Ideally I need something wider and faster but budgets are budgets.
Very happy with the K-r even if the weather has been so bad I should have stretched a little and gone for the K7
The K-R low light performance was the final factor in the end. The K5 would have been lovely but ££££££££
Rob
Rob
Cars: Banham Frogeye Sprite, 1975 Series III Land Rover SWB, Citroen C5 Tourer
Cameras: Canon G10, K-r, Sigma 18-200, Sigma 100-300
Calne,
Wiltshire,
UK
I am sure there is something obvious here. The camera is fine with a DAL lens and while I cannot check the manual lens it seems to be OK and was sold to me as being in good working order.
Any help and guidance no matter how basic much appreciated.
Rob
