K-r focusing, 5 point or one, help please?
Posted 29/01/2012 - 15:24
There are several options for AF behaviour on the K-r.
Centre Only
Manually Select
Automatic 5-point
Automatic 11-point
It will focus on the most prevalent phase/contrast difference. If you want to make sure all AF points are working, just set it to manual and focus on ha hard line, change in contrast with each point. The focus points will only flash up when it is the one being used for that scene and confirms focus.
Centre Only
Manually Select
Automatic 5-point
Automatic 11-point
Posted 29/01/2012 - 15:35
Although I don't have the K-r...
After half-pressing the shutter button and focus is obtained, the camera will indicate the point(s) on what it has focused. And in your example that is the center point.
So nothing is wrong.
Posted 30/01/2012 - 10:23
Thanks chaps. Am I right in thinking that even though my focus point is in the centre, all my photographs should still be in focus and not blurred around the edges?:
Posted 30/01/2012 - 11:50
Hi Jan,
it all depends on what focal length lens you are using and what aperture.
The delight of a DSLR is that you can control what you are taking so well.
I personally use the centre spot focus (or manual) for most telephoto work and switch to the 11 point system for general use.
Try taking your photos in AV (aperture priority mode). Allow the auto ISO to go up to 800 and stop your lens down to F8 or F11 if you want more depth of field. Many landscape fans use a tripod and stop down to F16 and focus short of infinity, beyond this quality suffers.
Posted 30/01/2012 - 13:44
There seems to be widespread expectation that the red light indicates when the camera has focused, it doesn't. It only indicates which point has been selected.The focus points will only flash up when it is the one being used for that scene and confirms focus.
The green hexagon in the viewfinder display indicates when correct focus has been achieved.
Posted 30/01/2012 - 14:55
Thanks wvbarnes. You have just given me the push that I needed to venture forth from 'autopilot' mode and johnriley, you have just, in one sentence, put me right, on when the camera is focused. The green hexagon.
My only other question is this. No matter which of the three focus point systems I choose, when I look through the viewfinder I will see only one focus point lit up in red. Right or wrong?
Posted 30/01/2012 - 15:31
I have a K-r as well. With centre point you will always just get one red square. With 5 and 11 you often get one, but sometimes get two or more. It depends on what you are focusing on. Thanks wvbarnes. You have just given me the push that I needed to venture forth from 'autopilot' mode and johnriley, you have just, in one sentence, put me right, on when the camera is focused. The green hexagon.
If you are focusing on something that is all more or less the same distance away, like a landscape, you will normally just get one red square. If, for example, you are pointing the camera out of a window at a landscape, but the window handle is in the picture you will get one red square for the landscape bit and another for the closer focus of the handle. This is the multi-point focusing trying to ensure everything is in focus.
One square is usual, though, and perfectly normal. Try what i mention above and you should see what I mean.
Hope this helps
Posted 30/01/2012 - 16:15
milamber.Been and gone and done it! At last, I'm beginning to see the light, I think. I have been assuming and looking for all of the five points to show. What a 'Rodney'!
For the first time since I got my K-r back, I am able to go and do some photography, this Wednesday [weather permitting]. Up till now it has all been my back garden and using the 'autopilot'. I'll have a go using the 'Av' and 'Tv' and see what turns out. Thanks for the assistance gentlemen.
Merseyside
