K-m Burst Mode Problems...
Ni-MH would serve you better.
For info I use a set of Duracell rechargeables 2650mAh. About £10 from Currys
K10D mentions above why the problem occurred...... get the highest mAh rating you can to minimise the impact of this.
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Thanks for all your help.I was recommended the Jessops 2700mah Ni-Mh batteries. They are much better. I can burst on hi setting many times before they are showing reduced voltage. I also got myself a PK-A 50mm f1.7 for £40 with lens hood and filter. It's a great little lens, I'm loving it!
Phil.
I was at a birds of prey flying exhibition yesterday and encountered some problems with the K-m in high speed setting. I took five pictures in the burst with almost new lithium energizer AA's and the camera processed them and then said 'battery depleted' and shut down. As the batteries almost new I was very disappointed. I then started it up again and the battery meter showed full charge. Has anyone else come across this problem? I do lots of fast moving sport and maybe I need to upgrade already! I'm not sure these lithium AA's are up to the job.
Your thoughts apprecieted,
Phil
K-m/DAL 18-55/DA 55-200.
