K-5 horizontal alignment issues
davidstorm
Posted 12/08/2012 - 19:52 Link
I fear my K-5 will have to be returned to SRS. Whilst on holiday to Cornwall, it has developed a severe horizontal mis-alignment, i.e. in the viewfinder the image is perfectly straight, but when viewing the image taken it is sloping down to the left by a significant amount. I think the sensor has become mis-aligned.
The camera was bought new from SRS in March this year, I would be grateful for advice on who to speak to / how to get it fixed as it is well within the warranty period. BTW, it has not been dropped or jolted.
Posted 12/08/2012 - 20:08 Link
Just give SRS a ring and ask how you should proceed.
Have you tried operating the dust removal system a few times to see if it clears things up?
davidstorm
Posted 12/08/2012 - 20:13 Link
Hi John, thanks for the reply and suggestion. The dust removal is set to operate every time the camera is switched on; is this any different from activating dust removal ad-hoc via the menu?
Posted 12/08/2012 - 20:21 Link
I just thought a few shocks to the system might dislodge anything that might be causing the problem - maybe a long shot, but it's what I'd try.
bettyswolloks
Posted 12/08/2012 - 21:44 Link
Not really helpfull but how does the electronic level read? just wondering if thats out of kilter also.
davidstorm
Posted 12/08/2012 - 22:25 Link
The level has gone miles out too, I think the level reading is linked to the sensor, so both will go out of alignment at the same time.
ChrisA
Posted 12/08/2012 - 23:07 - Helpful Comment Link
Worth verifying what happens if you switch off horizon correction for exactly this reason.
davidstorm
Posted 12/08/2012 - 23:30 Link
Cheers Chris, I've just tested this and with Horizon Correction turned off the camera now takes straight images! I didn't even realise it was switched on, is it turned on by default?
I think the camera still needs to go back though as the calibration is obviously way out. This has happened suddenly, it was not like this when purchased.
bettyswolloks
Posted 12/08/2012 - 23:57 - Helpful Comment Link
Found this looks like what your describing?
davidstorm
Posted 13/08/2012 - 00:15 Link
Thanks for all the responses to this thread, it seems my K-5 has developed the all too common 'levels' issue that has been reported by many users. I find it ridiculous that Pentax cannot provide a way for users to correct this themselves as it appears it only requires a simple software correction. Why on earth is this not in the menus? Come on Pentax, give us a firmware update so we can put this right without having to send our cameras away. If it has happened to mine after 6 months or so (after being OK until then), it must happen to a lot of users outside the warranty period. I wonder how much they are charged to put this right?
