K-5 battery recommendations
Algernon
Posted 06/05/2011 - 13:12 Link
Steve Chasey wrote:
From a previous thread here - poss on k20D batteries - bought from here
http://www.digi-quick.co.uk/Camera-Batteries-for- Pentax-K-5__DM4471_7
My copy is in the grip of my K7. Not given it a heavy test, so can't comment on longevity.
(can't get link to work - but the url is there in plain view)
They also list a charger at £10.99..... Spend another pound for Free Del.
link
sorted78
Posted 13/05/2011 - 22:38 Link
I bought one from RobE17 as well and am very pleased with it - a smooth and pleasant transaction thanks.
(now I have 4 K-5 batteries and am also sorely tempted by a project involving lithium polymer cells and a cheap grip... Thanks to everyone for their help and advice.)
jeallen01
Posted 16/05/2011 - 22:23 Link
sorted78 wrote:
So far the first charge of my Pentax battery in the K-5 has lasted 1100 shots and has only just gone down to two bars
Ah, mine's only done half that so far, but then I have used live view and the flash quite a bit. Still impressive, though.
OTOH, long experience with the GX10 (K10D) and limited experience with the K5 is that everything is fine until they die PDQ! Can't say I've noticed a real difference with original and 3rd party batteries - but I rarely take more than a couple of hundred shots on a day, and then that is only at airshows.
MarkTaylor
Posted 18/05/2011 - 22:21 Link
johnriley wrote:
So far the first charge of my Pentax battery in the K-5 has lasted 1100 shots and has only just gone down to two bars.
I'd be interested on what sort of settings you use as I get a lot out of my Pentax battery but not nearly that much! Do you have automatic image reviews turned off for example, as I imagine that could make a big difference.
Edited by MarkTaylor: 18/05/2011 - 22:22
Smeggypants
Posted 18/05/2011 - 22:49 Link
I took 4000 shots at the BMF ( British Motorcycle Federation show ) on Sunday with 2 K-5s. I have both the info screen on AND the image review. (roughly) One K-5 took 3000 shots and the other took about 1000. The 3000 shot k-5 was having to autofocus my 135-400 sigma, a hefty piece of glass.
I used the Pentax batteries this time. I dint bother to look at the bars on the battery meter, but both cams were still going strong at the end
I think the my K-5s are much more energy efficient than My K20D/K10D ever was. I'm impressed.
Edited by Smeggypants: 18/05/2011 - 22:49
Posted 18/05/2011 - 23:12 Link
I use the shortest review time, but tend not to use flash. I do use playback to view images, but at the end of a session or a set of images within a session. I don't consciously try to save battery power and in fact have the auto shutdown switched off.
MarkTaylor
Posted 18/05/2011 - 23:22 Link
It never ocurred to me before reading this thread but now I'm starting to wonder if I have a sub-par battery. I reckon I get around 800 shots out of mine. One thing I noticed is the third party battery I purchased actually lasts longer, but until now I just assumed it happened to be a pretty good third party battery and it didn't make me think anything was wrong with my Pentax battery.
The only other thing that occurs is that I shoot in RAW+ which could possibly be making a substantial difference as I'm sure most users tend to stick with one format or the other - in effect I'm making the camera save every image to my memory card twice over.
(Since plenty of K-5 users have had sensor stains and/or focusing issues I suppose I'm getting off lightly if my only complaint is a slightly sub-standard battery.)
Edited by MarkTaylor: 18/05/2011 - 23:28
Smeggypants
Posted 18/05/2011 - 23:31 Link
If the 3rd party battery lasts longer I would say your Pentax battery is defective.
MarkTaylor
Posted 19/05/2011 - 00:55 Link
Yeah. I guess the warranty should cover this but it doesn't sound like the easiest thing to demonstrate without some kind of proper testing method. "My battery only lasts X shots and other people's last for more" sounds kinda weak and likely to provoke a response along the lines of "battery performance may vary...".
I'll record how many shots I get out of each battery on the next charge cycle and avoid previewing images on the LCD to keep things equal and we'll see how that comes out.
Smeggypants
Posted 19/05/2011 - 04:47 Link
A decent retailer that sold you a £1k camera shouldn't quibble over a battery issue.
I've had 3 K-5s now and 3 Pentax batteries, and I've had way way more than 800 shots out of a battery . Way over 2000 in fact, and that's including the LCD and AF working overtime.
Just get it changed. If the retailwr starts quivering over the issue then just tell them you'll spend your next £1k somewhere else. Life's too short
I know my 3rd party batteries off Ebay for a tenner will shoot 2000. End of this month I'm doing a big 4000 ( at least ) shot shoot again. I'll put the 3rd party batteries in from the start and see what happens. - So far they've been as good as the Pentax branded.
bretti_kivi
Posted 19/05/2011 - 06:25 Link
I left my third battery at the summer house after Easter. Number 2 was in the Grip at that point - showing orange on the display - and has been used as the "main" battery since; I'm 800 pics on and it was only just at red over the weekend. That's with using LV quite a bit, no internal flash.
I think you have a defective battery, the K5 kicks the K10's ass when it comes to battery life and the K10 wasn't too shabby to start with.
Bret
my pics: link
