K-3 II firmware bug? anyone else got it?
Posted 14/07/2015 - 19:11
its ok ricoh will give you an anwser in what say a years time
on a seriouse note though you would be better finding the email address for ricoh/pentak usa than the uk
Posted 14/07/2015 - 19:31
If you go to their UK website you can report issues through that.
Posted 14/07/2015 - 19:56
Went to UK website, to contact us. Loaded support form, filled all in than it asked me for camera model and I there's no K3 II in drop down selection menu. Had to chose: Other.
Pentax K-3 II, DA 50/1.8, Sigma 18-35/1.8, DA* 300/4, 1.4x HD DA Converter
Posted 16/07/2015 - 09:26
Got answer from Ricoh, direct copy from received email:
Thank you for contacting Ricoh Imaging.
Herewith we inform you that in "M" mode the camera doesn't adjust any settings because in "M" everything should be set manually.
What you would like to achieve should be possible in "Av" mode.
If you are in need of further assistance, please respond to this email or call our technical support center.
Sincerely,
Ricoh Imaging Technical Support
WTF?? Do they even know what their camera is able or not to do??
I sent them quote from page 90 of K-3 II manual, see what they think of that.
Sincerely,
Posted 16/07/2015 - 09:36
Told you they are as much use as a fart in a cullinder
Sorry john Riley but this as to be said
Pentax UK needs to be taken by the short and currys and given a good shake and people put in place that are passionate about the product not just there because it is a job
Posted 16/07/2015 - 11:17
How old is the lens you are trying to use? 'A Series' lenses were first produced 31 years ago so yours must be older. Microsoft etc. only support products for a few years.
Most old lenses haven't metered correctly on Pentax bodies since at least the Z-1 came out.
If you knew about Liveview you would know that it has to stop down the lens to show the picture. Is it stopping down? (I doub't it).
Posted 16/07/2015 - 11:33
Algi don't Pentax say all of there old lenses will work it is somthing they all go on about
Posted 16/07/2015 - 11:44
If it can't stop the lens down in Liveview it won't work correctly. I've never tried it because I use full manual and sometimes LV to help focusing, but never metering.
LV focusing isn't too hot either because the lens is usually stopped down
Posted 16/07/2015 - 13:36
I've tried with Tokina RMC 400 5.6 which hasn't got A setting and with Vivitar S1 105mm set to something else than A.
From K-3 II manual, page 90 Highlighted box:
How to achieve correct exposure with aperture ring not set to A:
1. set the mode dial to M
2. set the aperture ring to desired aperture
3. press green button, the correct shutter speed will be set
4. If the correct exposure cannot be achieved adjust ISO sensitivity
It works like that in viewfinder but not in Live View. When you press green button in live view you can hear lens stopping down and then opening and picture in LV blinks but it doesn't adjust aperture. The lens does stop down when taking picture.
It worked like that in both modes on K-5 II.
I think it's a bug and I think the guy from Ricoh who answered my query never had Pentax DSLR in his hand.
Posted 16/07/2015 - 17:36
I've just tried on a K-5 with a Pentax-K 50mm f/1.2 and it does seem to meter correctly in LV. LV is always wide open at f/1.2 except for the very short time it meters.
I also tried a Pentax-A 50mm f/1.4 and in non-A mode set at f/11 it closes down to meter and then opens up again. It seems to stay closed down for longer though.... nearly a second so maybe it meters differently than the K lens.
On the A setting it doesn't seem to close down, but the iris was partly closed anyway. If you shine a torch at the lens you can see the iris open and close.
Both lenses have perfect snappy aperture blades.
Possibly the K-3 works differently?
Posted 17/07/2015 - 14:51
After sending them quote from manual I got another reply today:
We have forwarded your case to our product specialists for investigation. They will test the camera in the same situation as you described.
After the testing is done we will get back to you with an advice.
Sincerely,
They got product specialists. I wonder what will be their reply?
Sincerely,
Posted 17/07/2015 - 15:42
Just checked on my K3 - using a non-a lens (in this case a Sigma 28mm) green button does work in manual mode and LV. After obtaining the correct exposure in M via green button, with viewfinder, I then switched to LV, stopped down by one stop, pressed green button and shutter speed halved. K3ii should behave the same!
Everything Changes
https://www.flickr.com/photos/arleimages/
Posted 17/07/2015 - 15:43
Posted 17/07/2015 - 16:09
To be honest I'm only sending those emails for the fun of it. That Tokina 400mm is the only fully manual lens I got and I don't use it at all. And I very rarely use LV, so for me it's a non issue. But it could be frustrating for someone else.
13 years
When manual lens with no A setting on ring is mounted and I'm in live view and in M mode the green button will not set the shutter speed. It works OK when using viewfinder though.
Anyone knows how to report that to Ricoh?
Greg
