K-3 front dial stopped working
Jonathan-Mac
Posted 16/11/2026 - 08:59 Link
At the weekend I took my K-3 out to shoot some raindrops on leaves and I've just realised that the front dial of the camera has stopped working. It rotates and clicks as always but has no effect on camera settings. I've checked by adding the grip and the front dial there works fine, so the camera is still usable as long as the grip is attached, though it's not ideal to only be able to use the front dial in portrait orientation.
Has anyone else had this problem and do you know how much it's likely to cost to fix?
MHOL190246
Posted 16/11/2026 - 12:35 Link
Does it work withe the grip removed? If not, a couple of suggestions! Remove the main battery for about 60 seconds; try the depth of field level a couple of times.
Having Googled the problem, it seems that it is an issue that often comes up dating back to the K20D
Jonathan-Mac
Posted 16/11/2026 - 14:50 Link
It doesn't work with or without grip, nor after removing the battery for a while. It's completely unresponsive.
It's no great surprise that one of the main controls on a camera stops working after years of use. I use the rear dial far more, I almost always shoot in Av and use the rear dial to control the aperture.
So far I have had a rough estimate of €140 plus tax (€170 with VAT) but for a firm quote they would need to have a look at the camera. For about €80 more I could get another used one.
MHOL190246
Posted 16/11/2026 - 15:34 Link
How about changing the the front dial to control aperture etc - it is doable in the 'customising buttons & dials' section of the manual?
Michael
