jammed extension tubes
katiem111
Posted 09/04/2011 - 21:55 Link
hi all, bought some cheap tubes, fixed them to my k-x and 50mm,but now i cant get the tube off my lens, its stuck fast. any advice welcome
S**t happens, but usually before I can get my camera out
SteveEveritt
Posted 09/04/2011 - 22:02 Link
Is there a small silver protrusion on the side of the tubes, if so push it downwards towards the camera then twist off the lens.
katiem111
Posted 09/04/2011 - 22:15 Link
Steve, you are a genious! I did fiddle about with it, but it fell out, screwed it back in but didnt know what to do next. All fixed now, I owe you a pint!
cbrog
Posted 09/04/2011 - 22:19 Link
If they are the same cheapies that I bought i.e., made in China, makers name Qinfeng, I had the same problem when the small silver protusion referred to by Steve, fell off.
Solved by unscrewing the tubes from the last ring left attached to the lens, it is then quite easy to pull down the metal spring strip together with the pin which prevents the lens from being rotated.
Edited by cbrog: 09/04/2011 - 22:20
katiem111
Posted 12/04/2011 - 17:40 Link
Yes, cbrog, easy when you know how as the saying goes
