istDS with AF360FGZ as slave flash ?
The AF360 can, however, work in "regular" dumb slave mode - and this is what you've probably got set.
I'll look out the exact settings for you...
* Page 49 of the AF360 manual. Set to "SLAVE2" (dumb mode)
* For use, switch the power to the mid point, and the slave mode to "S"
* Put the AF360 in "A" mode (using the mode button)
Now, the AF360 should trigger twice, once for each flash of the popup on the *ist-Ds. In theory all should work fine (actually I used this with a Canon S30 for quite some time).
The only thing to watch out for is the flash distance of the AF360. If the preflash uses all the juice of the AF360 you'll get nothing for the main flash of the popup and the picture will be massively underexposed. Just so you know
21 years
