ist DS in camera multiple exposure - is it possible?
Posted 08/11/2008 - 21:30
Not as far as I know. If it is possible never found out how in years of owning one. I don't remember anything in the manual about it either.
Posted 08/11/2008 - 22:06
I had a DS and don't remember any multiple exposure feature.
There is no reference to "Multiple Exposure" in the manual - which is online:
http://www.pentaximaging.com/files/manual/istDS_repl_061405_web.pdf
K10D has Multiple Exposure.
~Pete
Posted 08/11/2008 - 22:14
The ist D had a 1-9 shot multiple exposure setting.
http://forums.photographyreview.com/archive/index.php/t-23520.html
But I can find no way or reference for the DS.
Posted 08/11/2008 - 22:41
On the DS, you need to do the following:-
Click on th fn button, click on the up arrow, and select Drive Mode Auto Bracket.
Then click on the Menu button.
in the rec mode, go to Auto bracket.
use the right button twice and the various brackets will come up. select what you want, press ok.
When you want to shoot brackets, just choose the fn and up arrow (only 3 brackets shots will be made though)
Hope this helps.
Iain
Hope this helps.
Iain
Some Cameras
Posted 08/11/2008 - 22:55
"Multiple exposure" usually means multiple exposures on a single frame. Bracketing makes multiple exposures on multiple frames.
~Pete
Posted 09/11/2008 - 00:10
Fair enough Ice, I thought that is what the OP meant.
I have just looked at the K20D, which has mutliexposure, I have not used, but the DS does not have it.
I normally use Photomatix, to merge a number of Exposures to make the photo. Not used the multi exposure accordingly.
Some Cameras
Posted 09/11/2008 - 01:26
Might be!
~Pete
Posted 09/11/2008 - 08:57
I did mean multi-exposure on a single frame. Apologies for the confusion.
There are references here:
http://64.233.183.104/search?q=cache:THZdDOXCzrwJ:https://www.fixya.com/search/p...
hoto.net/canon-eos-digital-camera-forum/00GKXT+ist+ds+multiple+exposure&hl=en&ct=clnk&cd=4&gl=uk" rel="nofollow" class="outlink" target="blank">http://64.233.183.104/search?q=cache:XVteYHTraRMJhoto.net/canon-eos-digital-ca...
Posted 09/11/2008 - 10:07
My handbook does not have any reference to multiple exposure in it, though the screen shot of drive modes does show it - I assume they took the same shot as they used for the D.
Also the second link only refers to the D, not the Ds.
Posted 09/11/2008 - 11:01
Thanks. Didn't think it could be done. Nice to know. Now, off to find a K10D. I do like the unpredictability of in camera multi exposure.
Posted 09/11/2008 - 11:27
That manual is for the *ist, the film version of the camera!, not the *ist DS.There are references here:
The manual for the *ist DS is here: http://www.pentaximaging.com/files/manual/istDS_repl_061405_web.pdf
~Pete
20 years
