ist D connection problems for remote assistant
Posted 17/04/2012 - 17:26
Compatibility mode to get XP could be the clue as RA is only XP compliant.
Do you have access to a pure XP machine that would prove that territory.
Now the lead, is it a third party/copy lead? I bought one that was incorrectly wired gave absolutely no response. Luckily caused no damage. If I remember correctly one of the signal(centre pair)was swapped with the 0ve power.
Found a genuine Pentax lead and all was talking to each other as it should.
Sorry to say I don't still have my notes from that escapade
Alan
Alan
Pentax A3, IstD, K10 50mm 1.7 M & A, 16-45, 18/35, 18/55(x2), 28/90FA, 80/320FA, AF36FGZ, AF500FTZ
Sigma 24/135, 150/500
Tamrom adaptall2. 500mm mirror. 70-300 DI.
Posted 17/04/2012 - 20:07
I didn't realise the *istD worked with Remote Assistant but you might try enabling administrator mode on your PC
Posted 18/04/2012 - 12:19
Thank you for trhe rapid and useful responses guys. Yes, RA will work with the ist D as long as you have greater than V1.0 firmware installed (this made it compatible). Yes...the lead in question. Claimed compatible from a 3rd Party and in fact says Cable-295 USB2.0 (though I thought the ist D was USB1.0 only!?) then "USB2.0-FEM Nikon 8PIN 1.8M Length". So I am presuming the same cable is used on a similar Nikon, maybe the elderly D100 (same sensor, so maybe similar internals/external connectors...don't know really, guessing!?). Like Alan suggests, I have sneaky feeling it's the cable, as it won't even see the camera to just download pics from the card (not that I want it for that, I'll use a CF card reader normally), so it would seem one is not seeing the other from the start. I'll have to dish the cash on a genuine Pentax USBI2 cable then I think. Will try running RA on an XP at work first though. Thanks for the help guys, appreciated - Anthony.
Great Britain
