Irfanview
Posted 02/03/2010 - 13:10
Just to check, is the version of Irfanview 4.23 or above, PEF support was only introduced at this point, however it does not make a distinction about what PEF version it supports. I know that photoshop cs3 will not read the new PEF format. I will download it and have a go tonight, see what happens.
Posted 02/03/2010 - 13:20
The version for both the program and the plug-ins is 4.25.
On a dark desert highway, cool Pentax K5 in my hand.
My Kit
K5 & 18-55 Kit lens, K7, Pentax 18-250mm lens, Sigma 10-20mm lens, Sigma 105mm Macro lens, Pentax 50mm 1.7 lens, Cokin P Series Filters
My Kit
Posted 02/03/2010 - 14:13
Ok, I will have a play tonight, what operating system do you have on your computer?
Posted 02/03/2010 - 14:43
I think you will have to install the Pentax codec on your new computer.
Posted 02/03/2010 - 14:46
I have Windows 7.
Ken - how do I install Pentax Codec on my computer?
John
John
My Kit
My Kit
Posted 02/03/2010 - 20:18
I carried out two installations on Windows XP & Windows 7 x64 desktops. The windows xp install worked fine and as expected I could view the PEF file from the File/Open menu, however the windows 7 version did not display PEF files. On investigation the pef format is not available in the "file type" window even after the plugin update was installed. I then change the "Files of Type" to "All Files (*.*)", selected a PEF file and it opened ok, although it did not display as a thumbnail. To summarise on your current windows install:
Select File / Open
Change "Files of Type" to "All Files (*.*)"
The select your PEF file.
I hope this helps if not get back to me
Graham
Select File / Open
Graham
Posted 03/03/2010 - 13:43
Posted 04/03/2010 - 12:14
Hi Ken & Graham
Irfanview now works with my PEF files thanks to your help.
As usual the Forum comes up with the goods. Thanks again
John
John
My Kit
My Kit
Posted 04/03/2010 - 12:43
I was a pleasure to be of help.
Graham
Graham
21 years
Birmingham
I've recently replaced my 7 year old computer. I used Irfanview to view my RAW images (PEF).
I've downloaded the program onto my new computer plus the most up to date plug-ins but I cannot find the file extension PEF. Irfanview was fine on the old computer and I could view my PEF files.
Anyone any idea where I am going wrong?? How do I find the PEF file extension?
John
My Kit
