indoor basketball
Posted 30/11/2008 - 10:34
Welcome to the forum, this makes me your first reply then.
Sounds like you have the basics already covered. I cover a lot of sports events some indoors and basketball is one of the faster moving ones, as you say normally in poor lighting conditions (unless of course TV cameras are present).
The only real help I can offer is faster lenses, usually in the form of prime lenses, pre focus where action is about to be, i.e. at the hoops, free shots zones etc.
Also practice, practice, practice at lots of events, don't be put off be a few blurry ones. The proportion of those goes down over time, don't tell everyone, but I still get a few. These are my more artistic shots, when asked.
If it were easy everyone would do it and I'd be out of a job.
"Hold Infinity in the palm of your hand" William Blake
My current Harem comprising: "Mistress" Pentax-A 15mm F3.5, "Good Lady" Pentax-A 20mm F2.8, "Friendly Lady" Pentax-A 24mm F2.8, "Deviate Lady" Pentax 28mm F3.5 Shift, "Street Lady" Pentax-A 28mm F2.8, "Bohemian Lady" Pentax-A 35mm F2.0, "Retro Lady" SMC Pentax-M 40mm F2.8, "Special Lady" Pentax-A 50mm F1.2, "Femme Fatale" Pentax-A 50mm F2.8 Macro, "Sweetheart" Pentax-A* 85mm F1.4, "Lady Luck" Pentax* 135mm F1.8, "Gorgeous Lady" Pentax-A* 200mm F2.8 ED, "Duchess" Pentax-A* 300mm F4.0, "Lady Gaga & Entourage" Pentax-A* 300mm F2.8 ED [IF], "The Queen" Pentax 500mm F4.5
Posted 01/12/2008 - 11:22
It is possible that your camera is back/front focussing with these lense, my K10D did and I was able to adjust it to compensate. Do a forum search for Back Focus and you should get some ideas on how to test this, you will need a focus chart and use auto focus at f2.8.
Are you using AF-C? It is possible to take the picture before the camera has locked on, though can also cause the image to be out of focus.
Flash: Metz 58, Metz 48
Posted 02/12/2008 - 17:59
Thanks for replying to this;
autofocus was indeed set to AF.C as I thought easier to follow the action. Looking at the pictures, top sides are sharper than middle sections, so I suppose camera could work as to backfocussing ?
Next weekend, I'll set up my camera on 45° stand for doing a focus test on a chart.
I'll keep you posted.
Many thanks
Many thanks
now pentax K10D, DA* 16-50mm f2.8, DA* 50-135mm f2.8, AF-540 FGZ
but loved my old K2 and series of lenses ...
Posted 06/12/2008 - 12:08
Here are results on my tests :
K10D camera on tripod, ISO100, Av mode, WB flash, AF.S, shake reduction off, used lens DA* 16/50mm set on 50mm/f2.8 with AF on,
lighting halogen 200W, fill-in camera flash and FG540 wireless,
applied self-timer on camera (12s),
toke some 10 shots starting from rendering image unsharp by out-focussing left & right;
autofucus gives clear picture on the 14mm front lines of page;
vertical line : centered fine line on viewer for shooting; also here unsharp center; side is sharper to the front;
I suspect this is a front-focus problem; if so how can I adjust this ?
many thanks for replying
experiencing with settings results in :
1600ASA, multi segment metering, Tv mode, WB artif. light or flash; autofocus set on lens, image stabil. on body;
results without flash : 1/60 over 1/125, f 2.8
with flash : 1/180 with some varying f;
nearly all pictures are unsharp;
I tested also focussing on a static portrait with some background; this results in a sharper image when I use manual focus;
can anyone comment on what I am doing wrong ?
many thanks & KR
