In his face
K10D
Posted 27/02/2015 - 10:38 Link
Taken at Fremantle
35mm lens, f/3.5, 1/100s, ISO100
McGregNi
Posted 28/02/2015 - 01:53 - Helpful Comment Link
Its a compelling subject, and the narrow depth of field is appropriate. Unfortunately the very bight and complex OOF background on the right acts only as a major distraction. It pulls attention away from the face, which is also not helped by being mostly in shadow.
I think this either needed a different shooting angle with only sea in behind, or if not possible then I think technically its a classic case where some HSS flash would do the trick, with the background brightness pulled right down with underexposure, and the flash lighting the face ... this should also even out the contrast on the face. Its an idea perhaps worth trying if you get another chance .....
K10D
Posted 28/02/2015 - 03:42 Link
I will give the HSS flash a try Nigel as Freo is the Whitby of West Aus as well as the San Francisco of Australia, culturally and I'll be there again today link
McGregNi
Posted 28/02/2015 - 04:00 Link
It might prove an effective technique I feel with this .... I'd be looking for maybe around 2 stops underexposure on the ambient. There's not much trouble to flash-light this subject as he's all on his own, so there shouldn't be any shadow problems, although I guess some sort of diffuser on the flash head would help.
I like the 2nd one very much as there's more power in the face through it being more in the light and front -on. You've done very well with the OOF effect, it's just that that bright and colourful background is a real challenge!
Edited by McGregNi: 28/02/2015 - 04:00
bwlchmawr
Posted 28/02/2015 - 07:28 Link
A nice link between the statue and the out of focus ships.
Best wishes,
Robert Adams
Ernst Hass
StephenHampshire
Posted 28/02/2015 - 09:04 Link
I think the first shot works well, because the out of focus and bright area IS the subject, the statue is looking towards this, the "lure of the sea" The second shot s just a picture of a statue, the first tells you something about mankind's connection with the oceans.
K10D
Posted 28/02/2015 - 15:34 Link
Another variant from today. Tight shot with flash, unfortunately I forgot the diffuser!
McGregNi
Posted 28/02/2015 - 18:45 Link
That's very nice! I like the contrast balancing and the background can still fulfil it's 'purpose' at a lower brightness level. The fill on the statute evens out the contrast on the face beautifully... Sure, maybe a diffuser would reduce reflections more .. But in any case, great job!
Edited by McGregNi: 28/02/2015 - 18:55
StephenHampshire
Posted 28/02/2015 - 19:48 Link
You see for me, that last one is definitely worse - distracting highlights on the statue's face, (definitely would be improved with a diffuser on the flash) no context to the background at all. The first has a terrific diagonal composition with the line of the statue's eyes, he is throwing a wistful glance at the boats in the background, which are an important part of the overall composition. I would concede that I might run a grad ND filter in software to darken the top right corner a tad, a smidgeon, a whisker, but no more!!
Ah well, each to his own poison etc....
McGregNi
Posted 28/02/2015 - 20:33 Link
The problem I see Stephen, it's that you are viewing this as an ' environmental portrait' , ie with a strong emphasis on the connection of the subject to the environment.
But, this is not how the photographer has crafted the photo ... An environmental portrait demands a much smaller aperture and realistic rendering. The photographer has chosen completely differently, with a wide aperture and tight subject framing. This had the effect (I believe) of reducing the background to a much lower supporting role than the relationship that you are suggesting exists.
This is what I'm not seeing as a result of the photographers choices. In this case then, the positioning and dominant lighting on this secondary background element is only distracting, and needs technical control.
I understand how you want to view the photo, but I feel you are superimposing an alternative interpretation that does not exist in the visual reality of the image.
Edited by McGregNi: 28/02/2015 - 20:35
StephenHampshire
Posted 28/02/2015 - 22:07 Link
Nope. I'm ust saying I like the first one. Personally I often use a large aperture to blur a background even when it relates to the main subject It makes the viewer work a bit harder to extract the intended meaning. But I could be totally wrong, the OP hasn't actually said what he wanted to convey, I am merely passing on my feeling about the original photo. I've noticed from other posts on this forum that I appear to have a high tolerance for distracting backgrounds. I have a similar "problem" at home, where I often have a radio and a CD on at the same time. My wife just hears a incoherent mess, but I tune my ear to whichever source I want to listen to and filter out the other. I also respond visually to patterns, (which helps when I do crosswords as often I can see patterns in the letters which suggest words to me before I decode the clues)
The original image has a strong gradation from dark (lower left) to light (upper right) The boats are obviously boats without having a mass of distracting detail. The vertical of the head and neck on the left third is balanced by the vertical of the masts on the second right third (using a classical rile of thirds composition) The diagonal of the statue's eye line is married by the diagonal of the rigging (top right)
The wistful look ""in his face expresses the sadness and not being at sea. And you are right, this interpretation is entirely a construct of my imagination, but it is what makes the first picture work for me. But as I said, in my earlier post, each to his own.
jemx99
Posted 28/02/2015 - 22:19 Link
StephenHampshire wrote:
the second shot s just a picture of a statue, the first tells you something about mankind's connection with the oceans.
I agree - I like the 1st shot too. And to me the 3rd shot is just a snapshot of a statue.
McGregNi
Posted 28/02/2015 - 23:16 Link
... and I'm seeing a portrait of a statue shot at in interesting angle, but marred by excessive contrast and shadow on the face and a very domimant, over-bright and complex OOF distraction behind to the right which just pulls the eye back and forward to no purpose !!!
K10D
Posted 01/03/2015 - 08:44 Link
Expanding on the subject. The statue is one of two at the seamen's memorial, Fremantle.
The vertical columns are full of name plates engraved with the names of all of those men lost at sea from Fremantle.
I got there early today before the crowds arrived.
The full work
Maybe a subject that can have many facets that appeal in different ways to people.
I've seen shots of this with a sunset, cloudy sky in the background with fill flash, really good work by some one.
McGregNi
Posted 01/03/2015 - 13:08 Link
Great coverage of a most interesting spot ... Very interesting to see the wider context
... Still love the HSS one best though
