Ideal PC specs for Photographic work
Posted 28/10/2009 - 13:29
have you got a decent monitor? no 1 most important spec IMO.
after that I'd load up on as much RAM and HDD capacity as you can afford with a mid range CPU and GFX card.
but it does help
but it does help
Posted 28/10/2009 - 14:02
Make sure your graphics card can handle two monitors. You can then have your processing application open on one screen and other applications and file lists on the second.
Posted 28/10/2009 - 14:57
Too be honest it's the worst time to get a new PC.
DDR2 will get replaced fully by DDR3 in the future just like DDR2 did with DDR. So will you go for the new formats so that you can upgrade later or get bang for the bucks now but loosing the possibility to upgrade over 4 years?
I would suggest to take a look at the Intel P55 boards with in combination with i7-860, this cost probable £360 then you also need RAM and maybe a video card.
Two strips of 2GB DDR3 RAM will cost you around £80 and leaves you room to upgrade.
Graphics card is a bit hard, ATI new cards deliver a lot of punch for little money and they use less power.
ATI Radeon HD5770 would not fit in your budget though since it's £110.
But the card can also process just like your processor does and give a performance boost to Lightroom and CS4. Nvidia cards have CUDA, that is basicly the same but the new ati cards use the new open standard that is in Windows 7 I believe, don't know if the other cards do???
This system here is probably over kill at the moment though but it will keep you running for at least 4 years and then you can upgrade it most probably quite easily to keep it running for another 3 or 4 years.
Posted 28/10/2009 - 15:05
TBH though Stefan I can't remember the last time we weren't in the middle of a format overtaking another format.
You can never do a budget upgrade with any sort of futureproof upgrade path. You either have to go bleeding edge now so that in 4 years you might still be able to get parts which fit, or you can go budget line now and accept that you will probably have to replace the whole machine next time.
It has been ever thus.
but it does help
but it does help
Posted 28/10/2009 - 15:30
Mongoose you make a point there.
I've bought the newest thing in 2003, amd athlon64, good motherboard with new PCI-E instead of AGP which was common then.
I've been upgrading along the way but AMD abbondand socket 939 quite quickly but bought the best processor there was for it for little money and upgraded my video card also, since i had PCI-E I could do that. If i had gone for the older AGP I would have needed to buy a new mother board, that comes with a different CPU socket so a new CPU was then also needed and I would have needed to buy new RAM since they wouldn't fit either.
So in the end I've save quite some money a long the way.
Since I bought the newest thing I could upgrade and I'm still running everything on it. the CPU is now getting slow though so will need to upgrade but will try to get everything as new as I can so DDR3 just to be sure I can upgrade that in the future. CPU is always a problem though but DDR3 will be there over 4 years but DDR2 will become every more tricky.
The system I propose is around £550 (don't know your prices so converted those here) so only slightly over budget but still being bleeding edge new though. Only question is if he needs a new power unit or not?
Posted 31/10/2009 - 07:41
Thanks all... certainly given me some additional bits to think about.
Monitor - I've a Sony TFT that I'm pretty happy with, prints match colours on screen so I'm thinking "if it ain't broke..."
Interesting that none of the advice has recommended opting for the latest mega processor. Guess I just need to find a decent mid-range PC with a motherboard that will handle plenty of RAM and maybe have some room to increase later. Seems that most PC's on the market that can handle 8GB RAM will match the rest of the specs OK in terms of graphics cards.
Cheers again - has helped me take the focus off worrying too much about what processor to go for!
Spirit_of_will
My Flickr
My Flickr
Posted 31/10/2009 - 16:11
If you've got decent components in your existing system (Hard drive & DVD Rom), why not stick these into a barebones system?
All you would require then would be a graphics card and operating system (if you already haven't got this). Also more RAM if desired.
I opted for such an option 2 years ago, and highly recommend it (Intel Core 2 duo E6750 with 2Gb RAM). Coupled with a 256Mb graphics card (nothing fancy), it hardly breaks sweat running Vista Home Premium 32 bit.
It was purchased from Novatech;
http://www.novatech.co.uk/novatech/barebones.html
Adrian
Adrian
K5IIs, Sigma 10-20, Pentax DA 16-85, Pentax DA 55-300, Pentax 70 Ltd, Metz 44 AF-2.
Flickr: https://www.flickr.com/photos/ambott/
Posted 31/10/2009 - 22:55
we reached the point several years ago where unless you're doing it for a living and therefore every second makes a difference, the latest CPU doesn't matter a jot unless your gaming. An Athlon XP can crunch any numbers the average person will need fast enough that you wont see the difference between a 4 year old box and the latest machine.Thanks all... certainly given me some additional bits to think about.
On the other hand images keep getting bigger. RAM makes a big difference, particularly if you ever stitch multiple images into a panorama. Try loading 10x 10+MP image into Hugin and then pretend 1GB of RAM is enough!
Similarly HDD space just disappears faster and faster with the new cameras. you can never have too much.
but it does help
but it does help
21 years
Bedfordshire
I'm tempted to look for a 2nd hand desktop as well as looking at new. But I've been out of the loop on keeping up with PC specs. I'm especially lost when it comes to graphics cards and the like.
Would welcome any advice on what sort of specs I ought to be looking at to do justice to running Win7 64Bit, CS4 & Lightroom, scanning 120 film via my Epson 4990, etc.
I've probably got £400-500 to play with and would be happy to find a decent base to upgrade on.
Cheers!
Will
My Flickr
