I-USB7 vs. I-USB17
junousia
Posted 28/12/2011 - 06:46 Link
Any ideas what the difference between I-USB7 and I-USB17?
USB-cable's outher sleeve of my K-x is a little bit damaged and I need the new one, and I worder is also I-USB17 suitable for K-x (original was I-USB7).
Best Regards
Jukka
flickr
"If your photographs aren't good enough, you're not close enough." - Robert Capa
fritzthedog
Posted 28/12/2011 - 09:00 Link
Hi Jukka
There is no difference between the two. The 17 will work fine with your K-x
Carl
womble
Posted 28/12/2011 - 09:14 Link
Could a mod please move this to the correct forum? Many thanks, K.
Posted 28/12/2011 - 09:53 Link
Moved to General Digital Photography.
Posted 03/04/2012 - 14:11 Link
Hello All,
Just found this thread while searching for 'I-USB17' which is what I need to replace for use with an Optio T10 aqquired in the U.K..
I don't mind if I end up with a third party cable; but some sellers advertise it as a mini 4-pin and others as a mini 8-pin, which concerns me a bit.
Pentax don't appear to publish spec's detailing the camera port type or the cable itself.
Can anyone please confirm which plug should be attatched to I-USB17?
Thanks in advance.
