Hyperfocal distances
Posted 23/01/2011 - 21:14
Great so for my 1000-4000mm telescope that works out at 3.125km at the wide end (which is f16) to 12.5km zoomed in (f64) no wonder focusing it has been a pain!
Can you explain how the calculated hyperfocal distance of 4900mm (4.9m) has you setting the focus to 2.5m ?
Posted 23/01/2011 - 21:42
sorry, yes, you're correct. Set the focus to 5m and everything from 2.5meters on will be in focus.
My example was crappy. I'll post up some video on Vimeo when I get hold of an account and show what I've used this for on the 7D.
Bret
Bret
my pics: link
Posted 23/01/2011 - 21:49
Here's an online Depth of Field calculator http://www.dofmaster.com/dofjs.html
And here's one which I have on my android phone http://www.appbrain.com/app/depth-of-field-calculator/cn.kamakama.android.dof
Posted 23/01/2011 - 21:54
I downloaded the windows version of the DOFMaster calc. Very good
Posted 23/01/2011 - 23:36
I like Photobuddy on the iPhone, it contains a bunch of photography info, some parts are a bit unnecessary, but there are features I find useful including the DOF calculator, sunset/sunrise calculator, and the moon phase tables.
Tim
Posted 24/01/2011 - 18:04
I read some interesting advice in a copy of "The Asahi Pentax Way" of a vaguely related nature. They advocated that if shooting a landscape you set the lens with the infinity position aligned with the DOF mark for the aperture you're using, as opposed to just setting the lens to infinity. The rationale was that doing this means you're in focus from infinity to a much closer distance.
Most wider angle Pentax lenses (28mm and the Super Takumar 35mm) have orange numbers. Line these up and it becomes a panfocal lens where everything is in focus from infinity to a closer distance.
Posted 24/01/2011 - 18:26
That's what I do. Or John's method where you just focus a third of the way in to the scene, select a small aperture, and hope for the best!Most wider angle Pentax lenses (28mm and the Super Takumar 35mm) have orange numbers. Line these up and it becomes a panfocal lens where everything is in focus from infinity to a closer distance.
But what if Pentax provided the following facility - focus on the nearest point that you want in focus, then on the furthest. The camera then automatically adjusts the aperture and focus point to ensure both points are in focus. I believe this system has been implemented on some Canon SLR's...
You could even have the camera analyse the scene using the different AF points on a half-press of the shutter, and then come up with an optimal focus/DOF setting.
Work: Helsinki; Home: Lahti
focal squared / f x 0.02
that's it. It's not complex.
Example: 28mm lens, f8.
28 x 28 = 784
8 x 0.02 = 0.16
784 / 0.16 = 4900
Therefore: set focus to 2.5m and f8 on that 28mm SMC-M and leave it.
I've been working with this at work for video footage and it works pretty well. Everything really is reasonably in focus, too, and that to infinity.
To make it really easy and to give some reference points, here a quick excel table, working in mm at both f8 and f16. You can do the rest of the maths yourselves
Set focus to these distances and everything from within half of the distance to infinity will be acceptably in focus.
mm....f...distance
10....8....625
12....8....900
14....8....1225
15....8....1406.25
16....8....1600
18....8....2025
20....8....2500
24....8....3600
28....8....4900
30....8....5625
40....8....10000
10....16....312.5
12....16....450
14....16....612.5
15....16....703.13
16....16....800
18....16....1012.5
20....16....1250
24....16....1800
28....16....2450
30....16....2812.5
40....16....5000
hth.
Bret
