Hoya 62mm Close Up +4 Filter
jamal_1088
Posted 25/04/2009 - 21:23 Link
can this filter fit on DA 18-55,
or anything you suggest, for macro pictures,
thank you,
regards
Posted 25/04/2009 - 21:32 Link
Not directly because the filter thread of the 18-55mm is only 52mm, but with the appropriate adapter ring sure.
If it was a typo in the title and you meant 52mm, then yes.
jamal_1088
Posted 25/04/2009 - 21:54 Link
thank you
jamal_1088
Posted 25/04/2009 - 21:57 Link
so, you mean 52mm filter would fit.
Posted 25/04/2009 - 22:45 Link
Yes it would.
jackitec
Posted 25/04/2009 - 23:16 Link
I have a 52-62 step up ring and a 62-77 step up giving many combination's for different filters, they are about £5 each, in your search engine type in step up rings and you will find them.
Jack.
jamal_1088
Posted 26/04/2009 - 06:45 Link
thank you very much.
stevejcoe
Posted 26/04/2009 - 06:51 Link
Be aware that when using a step up ring that the ring,plus filter may not fit inside the fit inside the lens hood. I have used a 52-58 plus polarising filter on the DA 18-55.
