How do you choose between macros?
Miles1010
Posted 04/03/2008 - 17:40 Link
This maybe a very silly question, but maybe some one has some images to demonstrate.
Why would you choose the new 35mm macro versus the DA 50mm or DA 100mm?
I appreciate the angle of view is different, leading to closer focussing. But if all three offer 1:1 magnification, isn't it just the depth of focus which makes the tangible difference between the three? Or am I missing something obvious?
K1, K5, 24-70mm DFA, DA18-135mm, DA35mm, Sigma 50mm Macro DG, Sigma 120-400mm DG, Tamron 70-200mm f/2.8
ikillrocknroll
Posted 04/03/2008 - 17:57 Link
Maybe consider not using it as just a macro, but as a 35mm prime or 100mm prime...
a 35mm would also provide more depth because of angles, telephoto lenses give a "flatter" view, and also, do you want to get right up to an object (35mm) or a few inches away (100mm)
Hope my opinion helped
Daniel Bridge
Posted 04/03/2008 - 18:09 Link
The field of view would be different, so you can use it to include more of the background, and help put the subject in contaxt.
This was with a 24mm lens on extension tubes, but hopefully it will give you the idea...
You would have to be a lot nearer your subject with the 35mm compared to a 100mm, so for instance, I couldn't have used one to get a shot of the dung fly I was photographing earlier today, when using my 105mm.
Dan
ikillrocknroll
Posted 04/03/2008 - 18:35 Link
Yeah, thats one of the reasons I cant decide what macro lens I want really
But I think im going to go for one around the 100mm range
George Lazarette
Posted 04/03/2008 - 18:44 Link
For documents 50mm
For bugs 100mm
For poisonous bugs 200mm
Daniel Bridge
Posted 04/03/2008 - 18:48 Link
For documents 50mm
For bugs 100mm
For George, as long as you can get!
Dan
Malo1961
Posted 04/03/2008 - 19:03 Link
George Lazarette wrote:
For documents 50mm
For bugs 100mm
Dan
Outch.........,That is real poisonous. What did you think of? This?
Martin.
Best regards,
Martin.
Daniel Bridge
Posted 04/03/2008 - 19:15 Link
Nah, not long enough. How about this?
Dan
Malo1961
Posted 04/03/2008 - 19:18 Link
Daniel,
Wacko Jacko could learn something about ''bad'', from you
Martin.
Best regards,
Martin.
Miles1010
Posted 04/03/2008 - 19:43 Link
Well thanks for the answers. I thought that a wider macro would give a greater depth of focus. I really like the toadstools Dan. Including a background like that in macro shots is not something I've seen too often.
Cheers.
hefty1
Posted 04/03/2008 - 20:32 Link
I already own the D-FA 100 Macro and it's fantastic for bug chasing and really shallow depths of field (as well as a great telephoto / portrait lens), however, I'm currently in a state of excitement about the new DA 35 Macro because I want a lens for copy stand work and product shoots that will give me a wider angle and a greater depth of field without having to stop down quite so much - the DA 35 looks like being perfect for this sort of work but I certainly wouldn't sell the 100, they each have their place depending upon the application.
If you're only getting one macro lens then maybe the 50 would be a good compromise - it strikes me as being neither one thing nor t'other though...
Joining the Q
Posted 04/03/2008 - 21:01 Link
Actually George, mischievously brief though his words are, has hit the nail pretty much on the proverbial head.
Personally, I prefer the 100mm for most applications, but the 50mm is ideal for documents as it avoids unnecessarily long working distances.
35mm on digital would in theory be roughly equivalent to a 50mm on film, but for me it's splitting hairs.
MX veteran
Posted 04/03/2008 - 22:25 Link
Like most things, there has to be a compromise. I have just bought the Sigma 70mm macro, this is one of the first shots I have taken so I am still learning how to get the best out of it.
Taken at F2.8 to see how shallow the depth of field is (very shallow as you can see)
I chose this focal length because:
a) I don't have to be over close at 1:1
b) Excellent reviews about it's sharpness and nice smooth out of focus parts
c) Cost, I got mine for £219
The Sigma 105mm was also considered (at the same cost).
K100D Super, 18-55, 50-200, Sigma 10-20, Sigma 70mm macro and lots of old lenses
mxuser
Posted 04/03/2008 - 23:12 Link
MX veteran that 70 Sigma has been on my wish-list for quite a while but the lowest UK price I have found is around £260.
Would you like to divulge your source at £219 ?
MX veteran
Posted 05/03/2008 - 00:46 Link
