Hot lights....cheap and easy
Posted 18/07/2008 - 15:52
you r welcome.
so it was easy enough to understand?
Posted 18/07/2008 - 15:56
Hi Don,
Thanks for the video. Not too bad to understand... however, I don't think it was that easy to work out where all the reflectors & 2 lights were. A quick sketch would have been helpful
Posted 18/07/2008 - 16:12
thank you Matt.
I will be sure to include a sketch in the final version.
when I redo the voice over, I'll make sure to detial the lighting change from short to long lighting also.
basically the setup is like a square, with the curtians on one side, the subject in the center, the camera on the side directly across from the background, and two lights in opposite corners.
one reflector below the subject, and one beside the subject. the subject is facing 45 deg towards the corner with no light. the second reflector is beside her in line with the two lights.
of course this setup will work with flash, and the lights/reflectors can be moved around a fair bit, but it is a great/easy starting point, I think.
Posted 18/07/2008 - 16:15
Thanks for the clarification Don. I did suss out the lighting as I've used similar setups. It was more for those newer to lighting
EDIT: Maybe we should start a "shoe-string lighting" competition or gallery i.e. how to use tin-foil, pieces of polystyrene, window light and halogens.
Posted 18/07/2008 - 16:23
I appreciate the feedback.
I'm gearing it towards less experienced people with little equipment/money.
So easy to forget how we started BEFORE we could afford to buy all the great, pro equipment.
but I hope people who want to get better photos, can grab a couple halogen worklights, or lamps like these and get busy making pictures/videos.
Whenever you see a newbie asking questions, it's usually "What should I buy to get better...?"
I'm an available light shooter.
There's two types of available light:
1) the kind you can't easily control, like the sun and the moon and the stars...
2) anything else available.
Posted 18/07/2008 - 17:02
explosives, firecrackers, pyrotechnics, electricity, chemicals.....EDIT: Maybe we should start a "shoe-string lighting" competition or gallery i.e. how to use tin-foil, pieces of polystyrene, window light and halogens.
added a quick diagram!
thanx!
Posted 19/07/2008 - 13:18
thanx!
Did you do your training at the Al Quaeda school of photography ?
thanx!
21 years
Winterpeg Manitoba Canada
But the setup works great with dslrs also (iso 400-800, f3.2-4)...
so I thought I'd share it here.
um, one thing though...
the voice over was a rush job, and I didn't mention the fact that at one point I switched from short lighting to long lighting, by turning up a lightsource beside my camera....
Eagle eyed Pentaxians won't let that slip...so I thought I'd tell ya upfront, that there is that one error, but I'll redo the voiceover before I podcast it to the masses!
It's just not finished yet, and may be down next week!
link
