Homebrew Flash Bracket
Posted 14/04/2008 - 08:37
Do you use another diffuser on the naked flashgun?
Or has Mrc C banned further camera expenditure?
Posted 14/04/2008 - 09:02
Yes i did George but i took it off to show the flash i was using. Do you use another diffuser on the naked flashgun?
These AF- 160 flashes have 3 settings low high and manual.
The low (green) setting was too low and the manual setting was way too high
So i settled for the high (red) setting which was kinda in between.
But angling the heads in any direction above, below or too the side also affects the outcome. So i'm experimenting at this stage
BTW i didn't need that adapter f we were discussing last night, I managed to get it all together with what i had at hand.
Camera:|K-7|
Posted 14/04/2008 - 09:31
It doesn't matter what the rig looks like, it's the results that count and that hoverfly is outstanding! Excellent work Clarky.
Joining the Q
Posted 14/04/2008 - 10:57
Sorry, said I wouldn't but I did.
BUT, that hoverfly shot is one of the best I've seen from you, and the lighting is perfect. So it doesn't matter if it looks a bit daft, it does the job very nicely.
How is it for doing portrait format shots?
Dan
(Thinking you might look like a massive bug looming over the poor subjects )
Posted 14/04/2008 - 11:07
Dan
Haven't tried portrait yet unless you count the cat But i think it will work ok. Sorry, said I wouldn't but I did.
Dan
Just a bit fiddly with all manual controls.
My wife already thinks i look like an idiot, now she is convinced
Camera:|K-7|
Posted 14/04/2008 - 12:36
well you wont have any difficulty getting portrait subjects to smile!
it does look a little funny, but the hoverfly shot proves it gets the job done so nice work!
but it does help
but it does help
Posted 14/04/2008 - 13:52
Love that hoverfly, too, Clarky! ''
Keith
K100D Super, DA 18-55, M 50 1.4, M 100 4 Macro
"The present is the object of vision, and what I see before me at any given second is a full field of color-patches scattered just so. The configuration will never be repeated." ~ Annie Dillard
Posted 14/04/2008 - 13:57
can't argue with results!
http://www.bhphotovideo.com/c/product/15544-REG/Delta_46190_Flip_Flash_I_Bracket.html
Posted 14/04/2008 - 15:28
A much more expensive solution:
http://www.speedgraphic.co.uk/prod.asp?i=8510&1=Novoflex+UNIMARM+Macro+Brack...
Posted 14/04/2008 - 16:07
[Haven't tried portrait yet unless you count the cat But i think it will work ok.
In case you misunderstood me, I meant how is it with the camera on its side (portrait format)? Can you still get the flashes either side opf the lens, rather than above and below?[Haven't tried portrait yet unless you count the cat But i think it will work ok.
Dan
Posted 14/04/2008 - 22:18
Dan
Sure you could I haven't tried it but i can't see a problem and if its a little short i can add segments to make it longer.
Dan
Camera:|K-7|
Sydney Australia
I had all this gear lying around and decided to make use of it all
After spending $18 on a couple of pieces here is the result.
And it seems to work pretty well as a fill flash when doing macro shots
Frankenbracket
A couple of shots with the flash. It was an overcast morning just after a rain shower and was quite dull.
Hoverfly on a flower.
Rusty our cat came out to see what i was up too and wondering what that strange this is i was holding.
I have only taken a handfull of shots but i like the initial results and its light weight and not as cumbersome as it looks.
