Histogram
Ava
Posted 11/03/2004 - 02:56 Link
I was taking some close up flower photos this weekend. I checked the histogram as I was taking them, and it looked fine. I then put a black backdrop behind the flower, and the histogram became so low that I could not even see it very well. I stopped up and down, but could not get a normal looking histogram. Could someone explain this to me? Some of the pictures still came out fine even with the strange histogram.
I also found that unless I use the manual setting on the istD when the lighting is low, the camera kicks the ISO up to 1600 on it's own.
Posted 11/03/2004 - 06:25 Link
Hi Ava!
The histogram is counting the number if pixels at each brightness (effectively). When you have a large expanse of black, say a backdrop with a single flower, or you are taking a stain-glass window from inside, a large number of pixels are black. In that case, the histogram will appear very low, or almost non-existant, with relatively few pixels non-black (to the right of the histogram). Your subject will be making a small statistical difference to the histogram.
It's not a bug You just have to understand what the histogram actually represents
Regarding the auto-pushing of the ISO setting - there's a custom function "Auto Sensitivity". You obviously have it enabled. For close up work, or work on a tripod, set this to "off". (Personally I have got it enabled in custom set 1, and disabled in custom set 2 - that way I can quickly switch between tripod and hand held settings.)
Hope that clarifies things for you!
Ava
Posted 11/03/2004 - 21:37 Link
Thanks Matt! That helps. No matter how many times I read the manual, I find there is still important information that escapes me!
