High Speed 360FGZ on MZ5n
Philip Taylor
Posted 13/05/2006 - 02:07 Link
Does anyone know if it's possible to use the high speed flash capability of the 360FGZ with the MZ5n?
It's great on the *istD but I need to use it with film. It may just be that I require a film *ist.
Mannesty
Posted 13/05/2006 - 09:50 Link
Of the cameras in the MZ/ZX series, only the MZ-S and MZ-6 have High Speed flash Sync.
You might look at the MZ-6. It works well, and in wireless mode, with the AF360FGZ and doesn't have the 'crippled' K mount as the *ist does. You'll probably find the MZ-6 is cheaper too.
Check out the differences at http://kmp.bdimitrov.de/bodies/MZ-ZX/index.html
Philip Taylor
Posted 14/05/2006 - 02:24 Link
Thanks for the info, I thought I might get lucky.
Do you know how the *istD works the high speed flash sync? Is it the flash working at 1/4000th or the camera body? And if so, how does it sync?
Mannesty
Posted 14/05/2006 - 08:45 Link
Page 32 of the AF360FGZ manual states that there is no HS synch speed limitation. The higher the shutter speed, the lower the guide number for daylight fill-in flash. Also, the guide number table on page 34 for HS synch shows shutter speeds up to 1/6000th/sec. HS Synch is P-TTL auto and is available in wireless mode.
The camera body works at whatever shutter speed is set on the camera, the flash duration varies between 1/1200th and 1/20000th of a second.
Summarised Extract from the istD manual:
On the istD, HS Synch is available with the AF360FGZ attached to the camera, or in wireless mode in any exposure program other than the green or B settings and only when the shutter speed is set higher than 1/150th.
Both manuals are available from the Pentaximaging web site in high quality PDF form, unlike the truly aweful photocopies of the older gear.
Philip Taylor
Posted 16/05/2006 - 10:57 Link
Thanks again, for what I'm intending to shoot, I can then set my *istD with 360FGZ attached to shoot at 1/4000th sec, and shoot the film on bulb for the exposure. Provided I work out my exposure correctly (with help of histograms on *istD and a completely dark room), I should theoretically be able to shoot at "1/4000th sec" on film.
I was going to shoot this for my Uni assignment but I have something else for that now, however, I will shoot this shot (of blender blades spinning [freezing motion]) just to see if it works. Will let you know how it goes.
Thanks again for the help.
