Help with Takumar Lens Focus confirmation
Posted 27/11/2013 - 17:31
There are no electrical contacts between an M42 lens and the camera so it would seem the camera thinks the image is not in focus. Perhaps what you are focussing on doesn't have much contrast for it to work.
Posted 27/11/2013 - 18:23
That seems the most likely reason, that or horizontal lines like venetian blinds. I've found many manual focus lenses can be a bit hit and miss.
Posted 27/11/2013 - 18:35
When I use manual focus lens on either K-r or K30 I have the auto focus set on the back button and I hold it down when manually focusing and focus slowly to give the camera a chance and it normally nails it.
Posted 27/11/2013 - 18:39
Thanks for the reply guys i see what you mean but its seems that on the 50mm once i've attached the lens it either works or it doesn't have used the lens today shooting the family at a Christmas market plenty of light contrast etc and then on santas grotto really low light and again it worked fine. As for the 135mm it has never worked strange one i will persevere!! thanks again for the advice
Malcolm
Website link
Website link
Posted 27/11/2013 - 19:05
Try enabling Catch In Focus, put the camera to AF.S and turn the focus ring slowly towards focus while holding the shutter button down, when focus is achieved it will automatically fire. Only Pentax do this and it's a boon.
Posted 28/11/2013 - 04:07
For catch-in-focus, you might have to short the pins on the camera body. If I recall correctly (I've tried it once), just place some tin foil over the contacts when you screw the lens into the camera does the trick.
With regards to focus confirmation:
If you try to focus while you're aperture is alredy closed down, there is often not enough light. Focus with open aperture, next close your aperture.
13 years
Tyne and Wear
Website link
