Help with lense choice please
jeallen01
Posted 09/03/2015 - 22:24 Link
Blythman wrote:
Depends how close you'll be. The 18-135 may be a better option
I'd take the Sigma - but I'd take the 18-135 as well if it's affordable for you because of the weight (MUCH less!) and the WR (and it's not much bigger than the 18-55), and it would give you options if you need something wider at times.
And also a 1.4x Pz T/c because that would give you a bit more reach with both lenses if you need it (and it weighs SFA!)
Edited by jeallen01: 09/03/2015 - 22:30
jemx99
Posted 09/03/2015 - 22:49 Link
The 18-135mm lens is VERY handy!
sterretje
Posted 10/03/2015 - 04:53 Link
Just a bit of a theoretical perspective. If you're close to the track and take a shot of cyclists passing you, 70mm will be far too long. A cyclist passing you at 2 meters distance needs a wide-ish lens (25mm or so) if you don't want to be limited to just a partial shot.
So if lens swapping poses an issue, I would rather take something that starts wide.
Can't advise what would be a suitable lens for your trip.
Jimd
Posted 10/03/2015 - 07:15 Link
Sigma 70-200 for the reasons already stated
exevalley
Posted 10/03/2015 - 07:33 Link
The thing is with mountain biking you are so close that you can put your hand out and touch the riders as they go by. if it was me i would take a 18-135wr which should cover all bases.
percy
Posted 10/03/2015 - 07:58 Link
As I said in my first post the Sigma 70-200 would be my first choice, but as others have mentioned the 18-135 would be a good bet if you are going to be closer to the action. Ideally you would need both lenses with you.
As a rough guide (if I've got my sums right), to fill the frame at 70mm you would need to be about 5 metres from the rider. Any closer and it won't fit the frame. At 200mm it would be closer to 15 metres.
But if you are this close, then the 18-135 is a better bet.
exevalley
Posted 10/03/2015 - 18:59 Link
Mountain Biking is a bit mad in South America, if anyones interested heres a link to a great downhill race.
https://www.youtube.com/watch?v=xIe6hYAdw_I&feature=related
Like i said its a bit Mad but i am sure you will have a great time.
Robin.
jeallen01
Posted 10/03/2015 - 19:19 Link
Robin.
Shooting that sort of action means you need a lens with a wide zoom range - and, if you are close to the action, then something like the 18-135 or 16-85 that is fast focusing and sharp (at the right aperture). Unless you are some distance away, the 70-200 lenses will be difficult at best.
Personally, I'd stick with the 18-135 unless you have a big budget!
Edited by jeallen01: 10/03/2015 - 19:20
stu62
Posted 10/03/2015 - 19:20 - Helpful Comment Link
if you are quick there is a 18/135 in the clasified on here for £150
srs as a 1.4 converter for les than £100
jeallen01
Posted 10/03/2015 - 19:33 Link
The converter needs to be the type with "Pz" (which were designed to operate with the old Pentax power zoom lenses) in the name, because only those have the contacts and connections which can now operate the DC focus motor in the 18-135 and the HSM motors in the Sigma HSM lenses (I have both types of lenses and can confirm this to be the case).
OTOH, most 1.4x T/Cs are NOT "Pz" types and won't allow autofocus with such lenses!
Edited by jeallen01: 10/03/2015 - 19:38
stu62
Posted 10/03/2015 - 19:40 Link
im shore that chris at srs will help him out there jeallen01
jeallen01
Posted 10/03/2015 - 20:09 Link
Funny thing - I went to the SRS site and could not find a link to the Used equipment part!
stu62
Posted 10/03/2015 - 20:10 Link
click on the ebay bit
all the secondhand stuff is there
Edited by stu62: 10/03/2015 - 20:11
jeallen01
Posted 10/03/2015 - 20:36 Link
Found it but it's not a Pz version
johnha
Posted 10/03/2015 - 21:25 Link
It depends how close to the race you'll be (I'd imagine you could be very close), especially the bit about 'coming at me and whilst they move past at speed'. I'd go for a wide-angle in the 15-20mm range - more depth of field and more scope for cropping in a chaotic environment, possibly using flash if that works for the riders. If you're close (within 15 feet), AF tracking probably won't be fast enough no matter which lens you go for.
