Help with jammed focus on Pentax F 70-210
Posted 31/10/2004 - 01:23
Personally, I wouldn't try it again on a camera until you've freed it by hand.
Try gently turning the AF coupler (with a small watchmaker's type screwdriver) back and forth to see if that frees it. You could try turning the focussing ring but it would be quite easy then to strain an internal mechanism.
Might be best to get a reputable dealer to take a look at it!
Posted 31/10/2004 - 06:01
The clerk tried the lens on a couple of the stores bodies.
I tried a screw driver gently in the focus drive. It is locked solid at infinity. There is some slack but no give at all. Guess I will try opening the lens and see what I can find.
The good news is when I went to purchase the lens the manager gave it to me free! - with lens caps.
Powell
Powell
Posted 31/10/2004 - 11:37
G'day.
I had a F 35-105 do the same thing.
I ripped it apart and found a small piece of grey plastic had broken off of somewhere unknown and was jammed solid in the gears of the AF drive.
Removed the jammed plastic, reassembled, And the lens is still working fine. Buggered if I know where the plastic that was jamming the AF came from.
Hooroo.
Regards, Trevor
OZ
P.S. getting the focus back to gether so that infinity was right was a real PITA.
Hooroo.
Regards, Trevor
OZ
be it a Glock or a Pentax, Any day shooting is a good day.
Posted 31/10/2004 - 19:43
Thanks Trevor
Any hints on best way to get to the gears? Any other tips from your experience appreciated.
Powell
Powell
21 years
Nanaimo BC Canada
I am going to buy the lens for $10 with lens caps. Hey the caps are worth that.
Has anyone ever seen this problem? Any suggestions or assistance in hopefully reviving this highly rated lens?
Powell
