Help with Astrophotography..
Anonymous
Posted 16/02/2004 - 10:00 Link
Hi everyone, ive just bought myself a K1000 with a f1.2 50mm lens
as my first real SLR camera, but am hoping to use it with Star/Moon pics aswell, which ive never really done before. Can anyone help me with what is essential for some cool NightSky pics?
Thanks for your help,
Ben.
Kim C
Posted 16/02/2004 - 10:34 Link
This isn't the easiest of subjects to start on! The first thing you will need is a good tripod and preferably a stopwatch if you are using a K1000. Most of your exposures are going to be longer than 1 sec. You could also do with a reasonably long lens. I have found 300 -400mm to be OK. You might get away with a 200 and a 2x multiplier. (Ebay is not a bad place to look but be wary) After that it's a little bit trial and error, the exposures will be outside the range of the K1000 light meter. The only camera I would trust is the LX because of the OTF exposure on Auto. I can try and look up some trial exposure times but a lot will depend on the lens and stars/moon. My best advice would be a visit to the library. Many books will have some of the information about what you are looking for. It's a question of looking at those, trying a few ideas and then deciding if it's your thing and how much you want to spend! A tripod would be useful anyway but I wouldn't spend too much untill you have tried it.
Kim
Anonymous
Posted 20/02/2004 - 04:35 Link
about 20 minutes at f/8 is a good starting point for exposures under a full moon sky with ISO 100 film. With your f1.8 lens you'd probably use it at f/5.6 which would halve the exposure previous exposure time (10 minutes because 5.6 is one stop brighter than If your using iso 50 film you'll be doubling your exposure times eg 40 minutes at f/8 (20min at f/5.6). and if you want star trails then you could set your aperture to the narrow end eg f/22 or 32 for 1hr 20 min or 2hr 40 minute exposures for long trails in a dark sky.
Chris
Posted 20/02/2004 - 09:23 Link
Norton's by Ian Ridpath is a standard astronomy work you can find in most public libraries which gives indications of exposure times that I have found to be accurate. For the moon, don't forget it's about 1/2 degree in diameter, which means that you need a long focal length to get a decent sized image. I use my DIY refractor telescope (1500mm focal length, 105 mm aperture) which works well, and 500 mm mirror lens, which works at a pinch.
Anonymous
Posted 07/04/2004 - 22:13 Link
I have exactly the same K1000 setup, go to
http://www.covingtoninnovations.com/astro/
for a freeware exposure calculator.
Hari...
Anonymous
Posted 06/05/2004 - 03:11 Link
After plenty of experimentation, I've had some fairly good results with "moon shots" using my LX and a 500mm mirror with 2x converter. Bracketing/compensating the exposure helps, as the moon is (by it's very nature) a big white thing on a black background. Can't stress enough the need for a decent tripod.
Anonymous
Posted 16/01/2006 - 15:54 Link
Try 'Googling' for 'barn door astronomy'.
Home made 'barn doors' can provide simple, driven equatorial mounts for astro photography.
I've just built my own computer driven version, but simple manually driven versions can give impressive results.
Don
Posted 16/01/2006 - 16:22 Link
Try this one out:
Slow film (100asa or slower)
f16
bracketed exposures from one to six hours.
lens set to infinity.
North star dead center of your viewfinder.
have fun.
Anonymous
Posted 18/01/2006 - 13:55 Link
That's fine if you want stripes instead of clear (pin point) images. Also, a six hour exposure typically requires low levels of light pollution.
I live in Cumbria, so my night sky is darker than for most of the UK, but still get significant pollution, mainly from the south.
Don
Posted 18/01/2006 - 14:38 Link
Original post asked for cool ideas.
My suggestion would not yeild stripes per say but rather rings of consentric circles, which I think can be cool especially when used as a compositional element, along with some archetecture, or landscape elements. Adds a little weird color shift, and requires no special/expensive equipment.
