Help to remove a mount.
Thordell
Posted 09/07/2009 - 16:08 Link
Help please, I am sure I am being very stupid but I have bought a set of rings which arrived yesterday. I wanted to check that the mounts were ok so fitter the set to the camera and then added a lens.
Problem is I can remove the mount from the camera but not from the lens, any ideas please? There is a machine screw in the mount but pushing, pulling nor a wiggle seems to make and difference, sure it is operator error but can’t see past what I have already tried.
Jackie H
K7, K20D, istDS, Optio SV, ME
Most used glass
50mm f1.4, 60-250mm, 28-80mm,
Pentaxophile
Posted 09/07/2009 - 16:51 Link
Mine has a little lever you push to release the lens. It is a bit stiff though. Can you upload some pics perhaps?
Mannesty
Posted 09/07/2009 - 16:58 Link
The locking pin needs to move back into the body of the tubes to allow the lens to be rotated and removed so you'll need to move/push/press/turn a lever/button to achieve that.
Edited by Mannesty: 09/07/2009 - 16:58
Thordell
Posted 09/07/2009 - 18:43 Link
Thank you, Thank you, easy when you know how all I need do now is learn to use them.
Jackie H
Most used glass
