Help Required?
Posted 05/01/2009 - 13:11
Nick,
Pls fill in your location in your profile.
What ISO were you set at?
You'll need a good flash to freeze action like that at lower ISO's.
All the best!
All the best!
Mac from Montreal
Posted 05/01/2009 - 13:17
Thanks, im still learning at the mo...
What would you recommend?
I was at 100 ISO
I do have a AF360 FGZ flash gun, but wanted to do continous shooting. I am fine outdoors...
I was at 100 ISO
Posted 05/01/2009 - 13:26
When shooting indoors, even with flash, you should be using ISO800 or more
That will increase the flash gun's effective range and ability (that's why the shots were underexposed - you were asking too much of the relatively small flash gun. You'll need a flashgun the size of a large brick to shoot in a large indoor space with ISO100 )
My recommendation:
* Use ISO between 400 and 1600
* Shoot RAW if you can (it will give you extra lattitude later)
* Use a wide-ish aperture (as you have already)
* If the car is moving that fast, you should pre-focus and anticipate, or perfect your panning technique
* Turn off SR (especially if using panning)
* Use trailing-curtain-sync on the flash
If the flash becomes the predominant light source, then don't worry too much about the shutter speed - the flash should freeze the majority of the shot. In fact, you probably want to use a slow-ish shutter speed, with panning, and trailing-curtain-sync on the flash (you'll then get "motion blur" with the car well defined by the flash burst).
Hope that helps!
My recommendation:
Hope that helps!
Posted 05/01/2009 - 14:16
and too add on the rest, if you use an higer iso you can drop the outputt of your flash so it can flash 3 or 4 times continously.I do have a AF360 FGZ flash gun, but wanted to do continous shooting. I am fine outdoors...
It might be a fun idea to use the flash at trailing curtain mode so that you get those speed lines like this link
Good luck shooting
I like taking pictures of radio control cars. I went to an indoor event yesterday, but was having difficulty in finding a decent shutter speed?
I was finding that a stop of F4.5 with a ss of 1/45-90 was showing alot of blur, but if i up the ss to 1/1000@ f4.5 i was getting dark shots...
These cars were doing between 30-50mph, these were indoor, a school hall, it was well lit.
Please help me.....
Im using a K10D
