Help re. 2x Converter
Posted 29/05/2010 - 10:45
If the Jessop TCs are like the Kenko TCs they are all Pz/AF but only certain ones AF with SDM. In Kenkos case Pz/AF-SHQ. So I think yours may not work with SDM only lenses.
Barrie - Too Old To Die Young
Posted 29/05/2010 - 11:29
Does it have 6 or 7 contacts !??
If only 6 then no lens info will be relayed to the camera, so it won't know what the focal length is set at, therefore can't move !!
My Sigma lens will not work properly with my x2, other lenses are fine !?
Posted 29/05/2010 - 14:20
Thanks all for your responses. Looks like it won't work with the 50-135* then (don't know any Pentax users other than you lot!!) It does have the seven contacts and looking at the exif the camera has lens and focal length, but clearly the un-magnified length. Which therefore poses the new question - should I turn off image stabilisation or not
Surrey
Does anyone know if this is simply a compatability issue, or should I be able to use SDM? The results in manual mode are not bad, so I may be tempted to just live with it, rather than returning the item.
Tony
