help please
Thedipper
Posted 17/03/2019 - 14:58 Link
hi all I have just bought myself an apple Imack I need advice on photo editing software for Pentax Raw/pixel shift thanks for your help Paul
JAK
Posted 17/03/2019 - 17:59 Link
Try Digital Camera Utility 5 that came on the CD with the camera.
Update it to the latest version here.
If you install just the update (which would be sensible) it normally requests you to insert the original CD for a licensing check.
Edited by JAK: 17/03/2019 - 18:04
Miles1010
Posted 17/03/2019 - 19:15 Link
The Digital Camera Utility 5 does work fine on an iMac. iPhoto will also import RAW files but not give you any control over the processing, nor will it handle pixel shift. You can use the two side by side, I suppose it depends on your workflow preferences.
K1, K5, 24-70mm DFA, DA18-135mm, DA35mm, Sigma 50mm Macro DG, Sigma 120-400mm DG, Tamron 70-200mm f/2.8
Thedipper
Posted 17/03/2019 - 20:14 Link
thanks John and miles wii have a look and download it will like to try some DNG pixel shift Paul
JAK
Posted 18/03/2019 - 10:42 Link
Hope you've got a large hard-disk.
